Started by Marpleman, May 26, 2010, 09:23:34 PM
0 Members and 7 Guests are viewing this topic.
Thanks Bob, what a wally, now changed.
andrewarles
A/c not populating
398644 / F-HBSE / DR-400/140 B / 2632 / AERO CLUB VOSGIEN
4011AB / G-TCTC / PA-28R-201T / 2831001 / MARIE-DOMINIQUE LOPEZ
A725A6 / N56MB / LC41-550FG / 411029 / AIRCRAFT GUARANTY CORP TRUSTEE
A8D24D / N668DS / DA 40 / 40.368 / AIRCRAFT GUARANTY HOLDINGS & TRUST LLC TRUSTEE
A01819 / N105JK / Cessna 172P / 17275306 / AIRCRAFT GUARANTY CORP TRUSTEE
A76B7D / N5775M / M20J / 24-1505 / AIRCRAFT GUARANTY TITLE LLC TRUSTEE
386E5B / F-PSGT / DYN'AERO MCR-M / 372 / PHILIPPE SERGENT (From Callsign FPSGT)
394C48 / F-GTCI / SR-20 / 1768 / AERO CLUB DU DAUPHINE
398843 / F-HCCD / M20J / 24-0842 / DAVID CARON
A/c name, cn and owner missing
385483 / F-BVED / BEECH 58 / TH-443 / ASSOCIATION FORLOC - FORMATION LOISIRS ET CULTURE
44A452 / OO-IBR / PA32
3D1030 / D-EEJO / HR10
391A37 / F-GGRX / PA 28 R 201 / 2837035 / ASSOC UNION AERONAUTIQUE DE LA COTE D AZUR / UACA
390DA4 / F-GDNE / SOCATA TB 20 / 332 / ETAT / DIRECTION GENERALE DE L'AVIATION CIVILE / SEFA
Field AN incorrectly populated
C0624C / C-GLFV as "Gulfstream Aerospace  G-V..."
A21FE6 / N236MJ as "Gulfstream Aerospace G-IV..."
018055 / 5A-UAD as "Bombardier Challenger 850..."
Others
49D0A3 / OK-XGC showing "..." in AT field.  Changed at my end.
Andrew
16 NM SSW of LFMV (Avignon)
27 NM NW of LFML (Marseille)
Arles, France.
Andrew, Many thanks again.
However
C0624C is a Gulfstream Aerospace G-V
A21FE6 is  a Gulfstream Aerospace G-IV
018055 is a Bombardier Challenger 850 with an AI of CRJ2
OK-XGC is showing as a B735 in the database.
andrewarles
Alan,
What I meant was that for those 3 aircraft they finish with "..." at the end of their names when populating the db.
Rgds
Andrew
Arles, France.
ACW367
Quote from: andrewarles on September 12, 2010, 09:22:52 PM
Alan,
Rgds
Andrew
Andrew in the original Navdata there are a number of aircraft that have the '...' as they had cutoff fields in the very original data they got.  It is similar to the dots you get on the reporter.
In the new DB I can confirm that there are no aircraft with '...' in the type field.  What had probably happened is the new data has not fully overwritten the original Navdata entry.  You can delete any records with the '...' from your own Navdata and delete the corresponding photo from your C:/ drive.  This will mean you will definately pic up the correct data from our DB next time you pick the aircraft up.
Regards ACW367
andrewarles
This a/c that I posted yesterday doesn't seem to be populating. Is it a problem at my end?
Andrew
Arles, France.
andrewarles
Hi ACW367,
Quote from: ACW367 on September 12, 2010, 10:24:47 PM
Just to be sure, the three dots I'm referring to are after the a/c name in the AN field and not in the AT field.
Rgds
Andrew
Arles, France.
Morning Andrew,
390DA4 is in the d/b at this end as it should be.  I presume that it is only the AT which is missing, in that case manually update.  If not it may be because you already had some data for the aircraft and this will not be over written  In that case delete what you have and allow the d/b data to be brought down the next time you see it.
I would assume that the 3 dots were not over written as ACW stated and also as he stated we dont have any... in the d/b now.
John Hargreaves
Can you update 4BCCEB TC-SGK of Saga Airlines please. Amended c/n is 29246/475. All other details are correct.
Thanks,
John H.
Thanks John,  saw you reply on the other forum.  Your updates are most appreciated.
Bob SEN
Evening Alan
3C48CB n/p   flight id BER666P
cheers
Bob
1/2 a mile South of EGMC/SEN
Evening Bob,
Another registration to cause confusion 3C48CB is the latest A320-214 for Air Berlin D-ABFK c/n 4433
Bob SEN
Thanks Alan
another for you....... 440448 flight id JAG1
cheers
Bob
Dont have that one yet Bob.
andrewarles
A few more updates.
A/c not populating
0640B9 (Callsign 5NBLW)
511036 (Callsign ESTLB)
E48580 / PT-PST
A3955D / N33VM / PA-46-350P / 4622179 / EAGLE ALEGRIA AVIATION INC TRUSTEE
343043 / EC-KJJ / 550 Citation 2 / 550-0415 / Pronair Airlines
484C4E / PH-JDK / Lambert M212-200 / 002 / B.A. Adriaens
3FAB24 / 86+36 / Bo-105P / 6036 / German Army
A76449 / N5757 / PA 46-350P / 4636114 / N5757 CORP TRUSTEE
3948E2 / F-GSHC / PA 34-220 T / 3433156 / THIERRY SCHMITT
AB877D / N842CD / SR22 / 0162 / AIRCRAFT GUARANTY TRUST LLC TRUSTEE
502C60 Latvia at 36000ft ?
Andrew
Arles, France.
