Antenna?
Started by Markus48, July 01, 2010, 02:50:16 PM
Markus48
When i first purchased Radar box a couple years ago
I used stock antenna that came with it and averaged 40-50
aircraft at a time.
  I then added outdoor aerial and pre-amp and averaged
about 90 hits at a time.
Now due to roof construction I'm temporarily using stock indoor
antenna again and only getting few hits at a time.
  Did past years of outdoor antenna use and pre-amp desensitize my box?
  Is that possible?
  Just wondering if anyone else had same.
  Mark
Maryland
Nope that shouldn't have an affect. Check whether the leads have come loose or whether its fully connecting with the box (sometimes the wire inside comes loose)
Markus48
Quote from: AirNav Support on July 01, 2010, 07:42:56 PM
Yes must be internal break possibly on stock aerial.
I tried plugging in other coax cable to box and get better results than antenna.
Thanks,will wait till I get roof aerial back up and running for sure test.
Mark
flybhx
Just resurrecting this one. I have recently aquired a used radarbox, mainly it must be said for use on the road. I find when running it with the stock antenna that it only picks up aircraft within about 10 miles of me yet the sbs box I use for home use aquires aircraft at up to 40 miles. Swapping antenna between them makes no difference. Any tips on increasing the range on the side where I have good line of sight please?
air7677
#4
Quote from: flybhx on August 12, 2010, 10:57:10 AM
Hi.
I have a laptop on my knee and the airnav box on floor, and the supplied aerial
on dashboard, i get up to 200miles or more depending on what elevation the road is.
S.F
flybhx
I'll have t take the car out to the top of a hill one day and se what I get. The house is in a dip but I should be getting more than I do. Would a larger piece of metal as a ground plane help?
Quote from: flybhx on August 12, 2010, 01:50:57 PM
Unlikely to make much difference. 10 mile range sounds well down (almost regardless of your topography)
Best get it checked out.
Yes, sounds like a faulty box - saw filter problem maybe.
RobinB
The roof of car is more than big enough :-)
flybhx
thanks for the advice folks, be nice if the skies cleared and I can go out and give it a try in the open before i have to get surfery on it.
flybhx
took the box out to Birmingham airport for a short time this morning and was getting about 20 hits up to a range of just over 50 miles from the standard antenna on the car. There are quite a few buildings around. Does that sound a bit more reasonable before I consider having to spend money on it.
air7677
Quote from: flybhx on August 15, 2010, 09:59:08 AM
To me as i take my airnav in my car i would say no, unless your completely surrounded by buildings you should be getting a lot more range than that.
You really should try open ground (& high if possible) to negate the effect of buildings. Having said that, it doesn't sound too clever to me and I would have it checked over.
The shop that supplied it can probably run a few tests for you with a different aerial. Airnav offer (and honour) a two year warranty on the boxes so if is bust but still under guarantee you will have nothing to pay.
flybhx
Thanks for that, as its second hand I'm not sure where I would stand in terms of the warranty.
flybhx
quick response received from support - send it in for checks. Thanks for telling me about the warranty Bratters
