Author Topic: Antenna?  (Read 8167 times)
Markus48
Antenna?
« on: July 01, 2010, 02:50:16 PM »
 When i first purchased Radar box a couple years ago
I used stock antenna that came with it and averaged 40-50
aircraft at a time.
  I then added outdoor aerial and pre-amp and averaged
about 90 hits at a time.
 Now due to roof construction I'm temporarily using stock indoor
antenna again and only getting few hits at a time.
  Did past years of outdoor antenna use and pre-amp desensitize my box?
  Is that possible?
  Just wondering if anyone else had same.
  Mark
 Maryland
Re: Antenna?
« Reply #1 on: July 01, 2010, 07:42:56 PM »
Nope that shouldn't have an affect. Check whether the leads have come loose or whether its fully connecting with the box (sometimes the wire inside comes loose)
Markus48
Re: Antenna?
« Reply #2 on: July 02, 2010, 03:27:05 AM »
 Yes must be internal break possibly on stock aerial.
 I tried plugging in other coax cable to box and get better results than antenna.
 Thanks,will wait till I get roof aerial back up and running for sure test.
 Mark
flybhx
Re: Antenna?
« Reply #3 on: August 12, 2010, 10:57:10 AM »
Just resurrecting this one. I have recently aquired a used radarbox, mainly it must be said for use on the road. I find when running it with the stock antenna that it only picks up aircraft within about 10 miles of me yet the sbs box I use for home use aquires aircraft at up to 40 miles. Swapping antenna between them makes no difference. Any tips on increasing the range on the side where I have good line of sight please?
air7677
Re: Antenna?
« Reply #4 on: August 12, 2010, 12:44:18 PM »
Hi.
I have a laptop on my knee and the airnav box on floor, and the supplied aerial
on dashboard, i get up to 200miles or more depending on what elevation the road is.
S.F
« Last Edit: August 12, 2010, 12:48:25 PM by air7677 »
flybhx
Re: Antenna?
« Reply #5 on: August 12, 2010, 01:50:57 PM »
I'll have t take the car out to the top of a hill one day and se what I get. The house is in a dip but I should be getting more than I do. Would a larger piece of metal as a ground plane help?
bratters
Re: Antenna?
« Reply #6 on: August 12, 2010, 02:45:07 PM »
Unlikely to make much difference. 10 mile range sounds well down (almost regardless of your topography)
Best get it checked out.
Re: Antenna?
« Reply #7 on: August 12, 2010, 04:19:37 PM »
Yes, sounds like a faulty box - saw filter problem maybe.
RobinB
Re: Antenna?
« Reply #8 on: August 12, 2010, 08:18:25 PM »
The roof of car is more than big enough :-)
flybhx
Re: Antenna?
« Reply #9 on: August 13, 2010, 04:56:49 PM »
thanks for the advice folks, be nice if the skies cleared and I can go out and give it a try in the open before i have to get surfery on it.
flybhx
Re: Antenna?
« Reply #10 on: August 15, 2010, 09:59:08 AM »
took the box out to Birmingham airport for a short time this morning and was getting about 20 hits up to a range of just over 50 miles from the standard antenna on the car. There are quite a few buildings around. Does that sound a bit more reasonable before I consider having to spend money on it.
air7677
Re: Antenna?
« Reply #11 on: August 15, 2010, 10:18:57 AM »
To me as i take my airnav in my car i would say no, unless your completely surrounded by buildings you should be getting a lot more range than that.
bratters
Re: Antenna?
« Reply #12 on: August 15, 2010, 10:25:00 AM »
You really should try open ground (& high if possible) to negate the effect of buildings. Having said that, it doesn't sound too clever to me and I would have it checked over.
The shop that supplied it can probably run a few tests for you with a different aerial. Airnav offer (and honour) a two year warranty on the boxes so if is bust but still under guarantee you will have nothing to pay.
flybhx
Re: Antenna?
« Reply #13 on: August 15, 2010, 10:42:09 AM »
Thanks for that, as its second hand I'm not sure where I would stand in terms of the warranty.
flybhx
Re: Antenna?
« Reply #14 on: August 15, 2010, 10:54:25 PM »
quick response received from support - send it in for checks. Thanks for telling me about the warranty Bratters
