Interesting Aircraft
Started by Allocator, March 08, 2008, 08:26:33 AM
John Racars
Hi All,
Untill sofar unknown reg flying around overhere in Europe: OK-TEC. Anyone any idea about this?
13 NM East of EHAM
ANRB:
Version: 3D - 5.00.072
PC: Windows 7 SP 1 - 64 bit
RadarBox24 station: EHAM4
John Racars
Quote from: Allocator on October 18, 2008, 09:12:14 AMI've got this as a Reims F172K.
Hi Allocator,
Thank you, and so it is in the ANRB database as well with "..." as aircraftcode,
But the OK-TEC I see is flying with CSA flightid's all the time so that suggest it is a pax jet..........
13 NM East of EHAM
ANRB:
Now I check my records I see that you are correct John!
http://www.airframes.org/ has 49D0A3 as a B737 reg OK-XGC and so does the GAS database at http://www.gatwickaviationsociety.org.uk/modeslookup.asp
I think that I'll do a manual update here :-)
jgrloit
Currently showing 2 KC135's at 26000 & 26500 both squarking 4610.
This from Hexham in the Tyne Valley.
Based in Hexham - Tyne Valley
Bethsalem
Just entered MyFlights over the Midlands.  Reg A6-HLA Douglas DC-8-63CF, Mode-S 8960BE, Callsign DUB010.  Registered to HVL - Heavylift International, built 1969.
Quote from: Bethsalem on October 18, 2008, 05:42:48 PMReg A6-HLA Douglas DC-8-63CF, Mode-S 8960BE, Callsign DUB010.  Registered to HVL - Heavylift International, built 1969.
No - it's C-130 Hercules A6-QFY.
Bethsalem
I think you might be mistaken DaveReid. This DC-8 is usually based in the UAE, but visits ATC Lasham near Basingstoke for periodic maintenance.
Quote from: Bethsalem on October 18, 2008, 10:24:50 PM
C-130 A6-QFY landed at Dublin shortly after 1900 local this evening, departed again about an hour later.  Logged overflying the UK on both legs at FL180/300kt and FL190/350kt respectively.
If it was a DC-8 there must have been a helluva headwind up there ... :-)
Terry
I think your both right,
                               Go look on "Airframes.Org",put in Mod-S code and three a/c are using that code and are active?
                           A6-HLA     DC8
                           A6-MAH    Hawker 800XL
                           A6-QFY     C-130H
All use the Hex 8960BE.
                                Regards Terry.
I'm a comparative newbie, so be gentle with me if this is a stupid question.   Why aren't unique codes used - surely any duplication (triplication in this case) could give rise to confusion and potentially dangerous situations?
Terry
CoastGuardJon,
                       I was thinking exactly the same as you,but i thought with Bethsalem and DaveReid having different A/C for that code i`d take a look on "Airframes .Org",and thats what came back,but i`ve had 2 sensitive A/C(Military)both using the same code,strange but there you go,maybe there`s an RB user who can enlighten us both on this subject out there?
                                          Regards Terry.
Quote from: CoastGuardJon on October 19, 2008, 12:24:18 PMsurely any duplication (triplication in this case) could give rise to confusion and potentially dangerous situations?
Yes it can and no it shouldn't happen.  National CAAs and military authorities are supposed to ensure that, at a given point in time, a specific code is only used by/allocated to a single aircraft.
Sometimes the system breaks down.
John Racars
Hi All,
After all KLM MD-11's fitted with ADS-B equipment now it looks the GEC (Lufthansa Cargo) MD-11's are coming up now.
My first GEC MD-11 tonight on the anrb-screen: D-ALCJ as GEC8211 KDFW-EDDF.
13 NM East of EHAM
ANRB:
Terry
     Just caught a nice little A/C in W.Australia,
                    Royal Flying Doctor Service Western Australia
                     Beech Super King Air
                     VH-FDG/BB-1172
                     Hex-7C192C
looking at the right place at the right time ,
                    Regards Terry.
