Started by orkney, November 10, 2010, 06:44:10 PM
Manuel, the first 2 are in the d/b.
Of the last 2, N6006F is now in the d/b.  The FAA has N8519F as reserved by Air Tractor but not assigned as yet.
Chris11
#1201
AAE541
FAA has it as blank as N8007Y was exported to Brazil on 27/12/2010
AAE541 had flight ID of N8007Y
Its PR-WAK BE58 miscoding,dont know its correct code.
flygfantast
4AB348 = SE-LZH, C172, Cessna 172R Skyhawk, c/n 17281329, Scandinavian Aviation Academy
Niklas
Cable: Ecoflex-10 (10m+1m)
chewycanes
flygfantast
Another one...
4A8D22 = SE-CIB, Jodel D113, c/n 789, Private owner
Niklas
Thanks again Niklas.  My d/b has it as a Jodel D-126
flygfantast
Quote from: Runway 31 on February 20, 2011, 05:00:09 PM
In the Swedish CAA register it says D-113. :-)
Niklas
Thats good enough for me Niklas, thanks.
LSZS
Quote from: Runway 31 on February 13, 2011, 06:05:34 PM
Hi Chris,
300101 - I-BEAU, Dassault Falcon 900 c/n 90
c/n is not 23?
Engadin Airport auf 1707m / 5600ft. Europas höchstgelegener Flughafen
http://www.flickr.com/photos/stefanobazzi/
#1212
Yes its 23, dont know where I got 90 from.  Its also in the d/b as 23. I also believe the correct hex for this aircraft is 300081 unless it has been re-coded.
chewycanes
Hi Alan
Another Irish reg not populating
4CA210
Brian
Hi Brian,
Its using the hex for EI-DFC which became EP-ATC and is an F100 c/n 11296 Iran Aseman Airlines, so miscoding.
