Started by orkney, November 10, 2010, 06:44:10 PM
Brian,
A61441 comes out as N491EP which is not assigned by the FAA, possible miscode.
Steve,
ADD75E comes out as you state N991LK, not assigned by FAA, possible miscode.
The mil hex as stated by Niklas is a US MIL tac code.
Have good long lay down with that beer, it will do you good.
That should be N700GR Anorak.
John Hargreaves
The newly delivered TAM PT-MXH, hex E48808, ihas populated incorrectly as an A320 -
Should read -
E48808  PT-MXH  A321  A321-231  c/n 4570  TAM
flygfantast
Not populating 4249CF (VQ-B??)
Niklas
Cable: Ecoflex-10 (10m+1m)
Cant find anything on it yet Niklas, hopefully the info will be available soon.
chewycanes
My usual miscode.
400C43 received today which should now be HB-JZT 4B1A61. Do you have any info to indicate it still uses its old code. If not i will run a separate post to ask people to check mylogs to see if anyone else detected it.
Brian
chewycanes
Not to worry found that LIBHOMERADAR has two recordings this month of the old code still being used. I am not going loopy......
Brian
Probaly only had one of its boxes amended.
Manuel Mendes
Hello.
Probably miscodes but just to inform and try:
343511  flight ID CASA65
CBEDFC no flight ID.
Thank you.
Quote from: Manuel Mendes on February 23, 2011, 03:30:41 PM
Hello.
Thank you.
Manuel,
I guess  you are in the area of Spain. I can confirm that hex code CBEDFC regularly flies over this way. There usually is no accompanying flight ID although strangely enough what can only be described as the Scottish flag of St Andrew is shown alongside the hex code.
I can only assume that the code is being used by test aircraft although which ones I have no idea.
Manuel
CBEDFC isnt allocated to any country and I am unable to provide any info.  The cross usually indicates a seriously knackered hex with no country allocation.
Cant find anything on 343511 either.
One to look out for, en-route from Madrid to Manchester, 344089 showing a flight ID of OEIAN.  Its A340-313 c/n 414 going to Air Livery for painting prior return to Iberia where it was formerly EC-HQN.
chewycanes
Evening Alan
40624C G-CLEU DG20 Steven Francis Tape (from GA)
AND
406005 EZY541R Flight ID but cannot find .
Brian
Manuel Mendes
Hello.
Seems that these two are missing by what I can see:
4910B2 / CS-DER / PA34 / Piper PA34-220T Seneca / Academia Aeronáutica de Évora / 3449236
4910A1 /CS-DEA / TOBA / Socata TB-200 Tobago XLS / Academia Aeronáutica de Évora / 2017
