Started by orkney, November 10, 2010, 06:44:10 PM
0 Members and 11 Guests are viewing this topic.
chewycanes
405CA6 G-CFKZ EUPA Nigel Peter Davis
Brian
Quote from: chewycanes on March 06, 2011, 07:26:52 PM400DAA G-TAAA SR20 TAA UK (From AF)
Quote from: chewycanes on March 06, 2011, 07:55:47 PMMissed the destroyed in remarks column of AF. I assume some one glued it back together and forgot to tell anyone.
Brian, out of interest, did you log 400DAA (G-TAAA) in your MyLog?  If so, how many messages were received - look at the MsgCount field for the Flight.  Just interested to see if this was a corrupted hex code or some other reason.
54901 - Jim
Missing from this morning's log:
A9CBFA / N730KP / RV7 / Joe Schumacher Van's RV-7 / Delta Kilo Papa Ltd / 71268
Thanks!
KOSH - Oshkosh, Wisconsin USA
flygfantast
4AA5FA = SE-IOZ, MU2, Mitsubishi MU-2B-26, c/n 320, SAAB AB
Niklas
Cable: Ecoflex-10 (10m+1m)
Alan,
Here's one for you to sort out just come onto 'My Flights'.
Mode S  AC8073 Registration N9040U
According to AN, it is a Cessna T206  c/n T20608988 Operated by Cessna Finance.
The corresponding picture shown alongside is of a United B737 registration N9040U.
According to Airframes, it is Shorts SC7-3A c/n SH 1979 operated by Lunama Aircraft Sales.
You pays your money.............
54901 - Jim
Flying overhead as I type this:
A25E69 / N2516K / COL4 / Lancair LC41-550FG Columbia 400 / Gerald M Wittman / 41069
Thanks!
Ian,
AC8073 is N9040U and is the Cessna T206H as detailed, certified on 3/2/2011. and detailed on the FAA website. The photo unfortunately is of a previous holder of the registration will be on your Data/Photo folderand should be deleted.
As you said you pays your money and our part is correct. :-))
chewycanes
Tarbat
In response to your question on G-TAAA it was in Mylog but i have since deleted it however i kept the following info
Detected 10.50 Lost 10.59 SA 6725 EA 24825 (did not keep msg count).
Because i have an external aerial with alot of flights i do suffer from corrupted codes which i try to exclude before i ask Alans help. Unfortunately on this one i missed that it had been destroyed and if i had checked the end altitude it should have rang alarm bells.
Brian
Quote from: Runway 31 on March 07, 2011, 06:14:12 PM
Ian,
Alan,
Thanks for sorting that one out.  I guessed that was the case with regard to the photograph of the United B737 however, it also goes to show that information on other databases (in this case Airframes) with regard to hex code/registration tie ups can be incorrect.
chewycanes
Evening Alan
0640F0 5N-FGU FA7X Nigerian Airforce
Brian
