Started by orkney, November 10, 2010, 06:44:10 PM
Standby with that.  there appears to be confusion with A320 G-EZUD which is also due today, confirmation awaited.
TEDDYBEAR
406442 G-EZGE Airbus A319-111 4624 en-route from Hamburg
Chris and all
40643E EZY8002 = G-EZUD 320-214 c/n 4636
and as stated by TEDDYBEAR
406442 EZY8001 = G-EZGE
Chris11
3985A2 - Air France not populating
F-HBNC Airbus A320-232 c/n 4601 according to GAS
Should be populating now Chris, just added it in a short time ago.
anorak
Has this one been done yet please?
Dave. Exmoor, North Devon.
Was added at 1833 tonight Anorak.
orkney
Hello
I think it was the Sjyhawk error he was meaning not that it wasn't added.
Andrew
anorak
Yep at 22000 feet it probably wasn`t a Cessna.  :-)
#1449
I acknowledge the error in the Skyhawk spelling which has been corrected.
However the hex AD4DB3 = N9563A which the FAA shows to be the Cessna concerned.
Unfortunately the initial reply sent only shows a little information giving aircraft details which show a spelling mistake, no where on it does it mention a height read out.  This additional information which was known but not passed origionally would have indicated tha tthe aircraft broadcasting the hex was not the rightful owner of that hex.
It is only the last reply, around 3 hours later which mentions 22,000 feet.  This additional information leads me to assume that either an aircraft is intenionally using the wrong hex or is miscoding accidenally which masks its true identity.  The callsign Flex 81 indicates to me that the former may be true in this case.
The code being broadcast however links to the registration given to the aircraft concerned, even if in this case the wrong hex was being broadcast by another aircraft.
Just been on the mode-s forum and the following has been given by Dave Reid which will answer the questions :
"Looks likely to be an octal miscode for AE2DB3. The latter code was noted
last week as JUNGLE81"
Likely to be an F15
My reply may also highlight a consequence of only passing partial information when making a request.
chewycanes
As you are aware i have over time found i get corrupted codes or aircraft giving the wrong codes. I now try to research them before passing to you so as not to cause any confusion. Some i think are corruptions but i find Libhomeradar has them logged as well.
Perhaps a few parameters added to the request may assist such as -
- Certainly for light a/c altitude can identify a corruption.
- Very short Msg count a/c may indicated possible corruption.
What ever you need i am sure all the users will be happy to supply.
Brian
Hi Brian,
The code supplied belongs to the aircraft details given even although I screwed up and wrongly spelled part of the details. I however put the details in the database for this aircraft at 18:22, just over half an hour before Anoraks post.
Flex 81 meant nothing to me as I am not very up to date with mil call signs and to be honest I didnt notice it when replying.  If I had it may possibly have rang a few alarm bells for me but then again maybe not.  I am thick at times and my uptake of cryptic messages can be quite slow.  I am assuming Anorak knew that this could have been a miscode or something but that wasnt mentioned in his post which just said " Has this one been done yet please?", hence my reply.  He was seeing the aircraft on screen and had a fuller picture than was available to me as i knew nothing of the altitude details etc.
Not a complaint but maybe a little less cryptic and to the point would be better.
chewycanes
401053 G-YEHA GLID Schleicher ASW-27B Bruce Louden Cooper
Brian
Chris11
00C462 Boeing 737-85P 28382/256 ZS-ZWR Kulula ferried 07mar11 NWI-BUD ex EC-HBM
