Database Update Requests
Started by orkney, November 10, 2010, 06:44:10 PM
0 Members and 9 Guests are viewing this topic.
chewycanes
4053C0 G-CJGS GLID Tomaz Stupnik (from AF)
Brian
Northern Watch
Just passed close by and populated as BC-A rather than a C17 was AE2FA9 / 08-8197 / US Air Force.  Is is the dreaded bug?
Keith
Northern Watch
Just picked up on the network and not populating:
A7C36B / N6JX / RV-6A / c/n 60289 / Jordan Thomas Mel.
Keith
Keith,
Yes unfortunately, go into d/b explorer and change it.
The RV is in the d/b so should populate.
Northern Watch
Quote from: Runway 31 on March 05, 2011, 06:01:58 PM
Keith,
Thought so on the C17 and updated by the Explorer.  The RV6 only showed the registration and mode S so went in later to update the other fields but did not appear, even tried a search on all the fields, strange!!!! However, I have now manually inputted the details.
Keith
Keith
If you have the updated d/b it should be in it.
Northern Watch
Quote from: Runway 31 on March 05, 2011, 11:05:54 PM
Keith
Morning Alan
With all the problems with the new DB I did not want to lose any of my hard work so I did not download the new DB but I did have autopopulate switched on and surley that should of placed it in my DB.  Not a big drama as this seems to be an isolated case but it did populate in amongst other USA aircraft in the network list but missing ac type hence trying to fill in the gaps in explorer and finding it missing.
Keith
Keith,
If the aircraft type only was missing this will be the dreaded bug in action which at this time is only resolved by manual entry.
This should be fully resolved in the next software version, hopefully!!
Northern Watch
Quote from: Runway 31 on March 06, 2011, 09:50:13 AM
Keith,
Yes hopefully the fix will work, strange it only appears to happen now and again.
Keep up the great work!
Keith
chewycanes
Afternoon Alan
401803 G-AXDI C172 Martin Frank Luesby (from GA)
44AE01 OO-KPA C172  ?
Brian
YXUphoto
New entry using wrong ICAO24.
A78D08 / N586JS / E50P / Embraer EMB500 Phenom 100 / Embraer EMB500 Phenom 100 / 50000183
Correct ICAO24 should be A78D0B
YXU
I think I am picking you up correctly from what you wrote.
A78D0B N586JS is in the d/b as an E50P c/n 50000183
There is no entry for A78D08 N586JP as it has not been assigned by FAA
Thanks Brian,
44AE01 = OO-KPA, Cessna 172R Skyhawk, c/n 17280521
chewycanes
400DAA G-TAAA SR20 TAA UK (From AF)
401803 G-AXDI C172 ? (in previous post not sure if you missed it ?)
501D1B Croatian ?
484046 Dutch ?
Brian
