orkney
Hello X
Thank you for that one. It is added now.
Andrew
X
Andrew
513012 Bosnian unknown was in again early this morning acting like a scheduled service, it maybe operating for Daallo Airlines as its arrival and departure time match a Daallo flight which I have nothing showing against. Have they leased anything from Europe recently e.g. MD80 or B737 type?
X
X
#1802
Andrew
Bingo, Found this report on Daallo three days ago
Eastok Avia/Sky Bosnia/Daallo A320-231 registration E7-SKA at Jeddah!
X
X
#1803
Andrew
Just in case, yesterdays non populators
344157   EC-LOC   A320-214   Vueling   4855
344088   EC-LKV   B767-383ERF   Gestair   24729/358 (in and out of DXB regularly)
A72812   N560MW   Vans RV-7   Michael E Wright   72633
X
orkney
Hello X
All of these are now done.
Thank you once again.
Andrew
X
Andrew
This known one did not populate on new d/b (thought I had sent this earlier)
896C2C  1224    C17   UAE - Air Force  UE-2    2011/06/29 03:09:12
X
orkney
Hello X
That one wasn't in but it is now.
Thank you again
Andrew
54901 - Jim
Owner/Operator updates for you:
A77535 / N58SX - Thomas P McAtee
A6AFBA / N53SX - Keith E Phillips
A636E4 / N5SX - James H Turk MD PA
A6B77D / N5317M - Aircraft R Us Corp
A66A7E / N512SS - 1802 Lima Inc
A6795A / N516SS - 1802 Lima Inc
A707ED / N552MA - OMCR Aviation LLC
A68845 / N52TG - Thomas J Goetz
A7B830 / N597J - Jehan Zeb Khan
A65CEA / N509RV - Paul R Eckenroth
A79A6B / N5895N - Archnet
A7AD57 / N594MA - Malone Air Holding LLC
A6DBE5 / N541CR - N80FT Inc
Thanks!
KOSH - Oshkosh, Wisconsin USA
X
Andrew
Some unknowns from today
86CEA3 B422
0200EA BOE518
Plus a note following ACW367's comments the other day
AE0443 00-9001 showed as a BC-B which is a C32B, thought this was now to be a named as a B752!
X
orkney
Hello X and Jim
Jim - all of them have now been checked. Thank you
X - all of yours are now done apart from 0200EA. I have only been able to find out that it is a new B738 for someone in Morocco.
AE0443 has the correct B752 code in the database, It is just The BC-B code is shown by Radarbox in this case as Radarbox  "Makes" an ICAO code from the long aircraft type for Boeing and Airbus aircraft, this can work - eg .Boeing 737-446 =  B734  but  a lot of the time it doesn't eg Boeing C-32B = BC-B.  This was a system devised by Airnav Before we started working on the database as the original sources didn't have an ICAO  field.  Now that we do have an ICAO field this system will be removed in the next Radarbox version so the ICAO code comes directly from the central database.
Thank you
Andrew
X
#1810
Andrew
Your last post explains some things I could not work out for types previously noted e.g. BC-A, BKC etc
I note all my KC135T's are now K35R's in AT box as ACW367 explained(as I had previously changed all to K35T), but as stated earlier can live with that as long as there is consistency.
X
jim_stockwell
Andrew
Picked up near Stevenage was 4A172A which is not populating
Jim
jim_stockwell
Andrew
Another not populating is ABA94D which GAS suggest is N850WA a TBM700 C/N 597
Jim
orkney
Hello Jim
4A172A and ABA94D are now added.
Thank you
Andrew
X
Andrew
I cannot remember if I confirmed that A6-ABU A320 is 89632C.
Seen at SHJ as such
X
