orkney
Hello X
I don't think you had given me that before. It is now added.
Thank you
Andrew
X
Andrew
Not populating
* 04C0CD                                                              2011/10/11 17:16:54
Departed JED
X
orkney
Hello X
I can find nothing for that one yet.
Thank you
Andrew
X
Andrew
EK76425 IL76 Rus Avia took off SHJ 1200 today but my box was off and wondered if you had hex for it, as I see no missing 76's or non populating aircraft that it could be (maybe landed from South under my pick up height).
X
orkney
Hello X
I cannot find any Mode S code for that one on our database or any others I looked at.
Thank you
Andrew
X
Andrew
Not populating in JED
A92884
8EFD0A
8EFD0B  SAR5002
Last two Not Allocated codes may be choppers from Naval base based on heights
X
orkney
Hello X
The only one of those I have found anything for is A92884.
Thank you
Andrew
X
Andrew
Thanks, dug into my logs and the last note of this 76 is in late 2010 and it was still using its old Libya code, but have not picked it up since. If it reappears as this I will let you know
EK76425   018022   IL76TD   10034 05167   Rus Aviation
Also not populating
A1F3AA OAE155
42460F VQBVQ
06A081  1
X
orkney
Hello X
I have added the first two but cant find any confirmation for 06A081. It might be A7-BFC based on the codes of A7-BFA and A7-BFB.
Thank you
Andrew
orkney
Hello X
I have also just added 0200EA that you requested yesterday.
Thank you
Andrew
X
Andrew
Found one that fits
8EFD0B SAR5002 could be 5002 AS565MB Panther c/n 6901 Royal Saudi Naval Forces
8EFD0A f/n now showing as SAR5006, guess its a new one!
X
X
orkney
Hello X
Thank you for that details. It is now added.
Andrew
X
Andrew
Even more details on one of my unknowns today
04C0CD DAO1504 ???? Daallo airlines (operating Hadj flights) possibly the unknown B734 I noted
0640CC looked like B747 in dark no other details
Also on network
A5A98D CMB392
484F16 KLM7453 ex KBFI (delivery?)
X
orkney
Hello X
I cannot find anything for your Daallo 04C0CD yet and A5A98D was already in. The others are now added.
Thank you
Andrew
X
#1829
Andrew
Beginning to suspect EK76425 is my unknown 60006C, as it first appeared within two days of the last report of it pinging 018022, and has been seen many times visually since, therefore I must have picked it up. It was in SHJ late 9/10 and could easily have stayed 36 Hrs.
X
