orkney
Hello X
I will add that one when you can confirm it.
Thank you
Andrew
Blueboy
Hi Andrew, one that stopped off at Prestwick on delivey
50FF1A  UR-CRTV  Cessna 208B Caravan  I think c/n is 208B2290
J.D
X
#1832
Guess that this is not WFU and being used for Haj flights
732427  IRA1373   EP-IAG  B742  WFU Stored (ex Iran Air) 2011/10/12 04:03:19
Plus all these at JED
* 0640BB                                                              2011/10/12 06:45:17
* 0640D4                                                              2011/10/12 05:10:15
* 4CC3E1  SVA5201  TF-AMZ  B744 All white SV t/s& t/l     2011/10/12 08:27:52
    600036  IRM5034                                               2011/10/12 03:28:53
* 683041                                                              2011/10/12 02:34:17
X
X
#1833
Andrew
While trawling through my 76's trying to deduce which is my other long time unknown 60005F (now that I believe 60006C is EK76425) I noticed a double entry with a mistake and out of date info,
00834 83502 is no longer current as EK-76737 or EK76592(2) and is now EK76599(2) (Soviet Air Transports) and EK76592 should have read 50808B (miscode of UR-76778) not 50805B. and new d/b put wrong reg entry of EK-76737 (four reg's previous).
It should now be one entry 50808B  EK76599(2) 00834 83502 seen SHJ yesterday as such and seen on box as 50808B Aug thru to 10/10. Blue and white c/s
Hope this is clear enough (these Russki's do cause problems!)
X
I
orkney
Hello X and J.D
I cannot find anything for any of your JED unknowns.
I cannot find a hex for EK76599
50808B  EK76599 Skiva Air is now added.
J.D. - UR-CRTV is now added.
Thank you both.
Andrew
chewycanes
Afternoon Andrew
8C6350 N898CT Falcon 2000 (Using incorrect ICAO24 address 8C6350 on mode-S, instead of AC6350 from AF)
484F5B PH-DTP Beechjet 400A JNL (From AF)
Brian
orkney
Hello Brian
That two are now added.
Thank you
Andrew
X
Andrew
Another new one
* 710208  HZMS73                                                      2011/10/12 09:01:09
X
orkney
Hello X
That one is in now as well.
Thank you
Andrew
X
Andrew
Quite a few unknowns appearing over here..this one surprised me!
* 424159            F900       2011/10/12 18:19:47
orkney
Hello X
That one is now added.
Thank you again
Andrew
X
#1841
Andrew
These Haj flights are driving me nuts.....Canadian, Portugese, Spanish and UK A330's on Garuda flights nos. Turkish A300's and B752's, Icelandic 744's on SV flights and god only knows what on Bangladesh, Sudan and Nigerian flights. Plus well past sell by date Lumps on PIA and Iran f/n's.
Now 4CC3C8 on a NGL3137 JED- Nigeria (I assume from flight path it took)
A078D0 12345678 rptd as HZ-135 C550
X
flygfantast
Andrew
4AADA4 SE-KMD, P28A, Piper PA-28-181, c/n 288490020, Private owner
Niklas
Cable: Ecoflex-10 (10m+1m)
orkney
Hello X
These hajj flights must certainly make a lot of money for the charter airlines at this time of year .  That two are now added anyway.
Thank you
Andrew
orkney
Hello Niklas
That one is added as well.
Thank you
Andrew
