X
Andrew
Not populating on network
E94046  RSU211
4CA9AD EI-ETG
8681AF
C0454D
X
orkney
Hello X
8681AF was already in and I can't find anything for C0454D. 4CA9AD and E94046 are added now though.
Thank you
Andrew
X
Andrew
One tied up
A07899 2256  C208 Cessna C.208 Caravan  UAE - Air Force
X
X
Andrew
Now my Kenyan unknown is on a Jubba Airways flight not Daaallo!
   04C0CD  JUB6004                                                     2011/10/12 20:42:34
   04C0CD  JUB6005                                                     2011/10/12 23:00:05
X
orkney
Hello X
Thank you for that one. It is now added
I Still know nothing about 04C0CD.
Thank you
Andrew
orkney
Hello lebelgepatte
That one is added now.
Thank you
Andrew
X
#1867
ACW367 and Andrew
If the list is correct then I believe one is tied up and two others narrowed down as follows
B743 5N-DBM Max Air NGL seen as 0640BA
B743 5N-BMG Max Air NGL seen as 0640D1
B743 5N-MBB Max Air NGL seen as 0640CC
B743 5N-DDK Max Air NGL probably 0640D4
B742 5N-MAD Kabo Air QNK 06409A seen as Biman in NW old c/s
B742 5N-DKB Kabo Air QNK possibly either 0640BB or 0640E1
B742 5N-JRM Kabo Air QNK possibly either 0640BB or 0640E1
However Maxair should have a B744 5N-HMB delivered 11/10/11 and maybe one of the two latter codes as only 0640BB was confirmed as a B742, and the other seen 13/10 possibly had winglets
NGL are operating one more B743 from Air Atlanta Icelandic TF-AME 4CC3C8
X
orkney
Hello X
All your seen as ones have now been added.
Thank you
Andrew
X
Andrew
two more local updates
6830A7   EK-76602(2)   IL76T   00034 27796   Ark Airways (miscode of UP-I7602)
68306D   EK-76603(2)   IL76T   0834 14432   Ark Airways (miscode of UP-I7603)
However neither have been on box since late 2010
X
orkney
Hello X
That two are done now as well.
Thank you
Andrew
X
Andrew
And another
683009 EK-76555 IL76TD  10334 16515    Ark Airways (miscode of UP-I7616)   ex UN-76385/UP-I7616
Last noted Jan 2011
X
orkney
Hello X
That is done as well.
Thank you
Andrew
Blueboy
Hi Andrew, not sure if its been reported but I picked up :
A3080C  N295   C25A   c/n 525A-0073  ex. I-LVNB
J.D
X
Andrew
I might have sent some of these earlier but just in case.
68305B    EK-76111  IL76TD   Rus Aviation (miscode of UN-76487) 00734 79367
504D06    EK-76300  IL76T     Air Highnesses (miscode of ER-IBF)  0834 10300
Unknown EK-76310   IL76TD   Air Highnesses 10134 09310
X
