orkney
Hello X
I think that one is indeed not flying any more from what I have found.
Thank you
Andrew
X
#1891
Andrew
Some more China Southern
7807C5  B-6817  A320-214        4880
780802  B-3147  E190-100LR      190-00477
780736  B-6136  A380-841        31
X
orkney
Hello X
The A320 and E190 are now added.
The A388 was already in.
Thank you
Andrew
X
#1893
Andrew
My back up file has 60083D as 4K-AZ60 IL76TD Silk Way 00934 99982 (re use of old AN12 reg) whereas the new d/b has it as 4K-AZ61 c/n 1023412411, which I do not have a hex for. C/n's are correct (Soviet Air Transports).
Looking back in my Logs both appear as 60083D so there must have been an update in 2010 that changed the info but cannot remember if I changed it or when updating.
Which is correct and do you know the missing hex?
X
orkney
Hello X
Both airframes.org and GAS as well as us have 60083D as 4K-AZ61. Sadly I do not know or can find the code for 4K-AZ60.
Thank you
Andrew
X
#1895
Andrew
You are right as on looking in my excel log I saw it as 60083D and read it off and reported it as 4K-AZ61 16/10/09. On 14/6/10 it reverted to 4K-AZ60 AN12 So I pass on how and why it changed in d/b!
X
X
Andrew
I believe 4K-AZ60 maybe miscoding as 4C0188 (ex YU-AMI) as it previously did as RA-76822 throughout 2010. However have not picked it up in 2011 so cannot confirm but maybe some other user has picked up this code this year.
X
X
Andrew
Re 4K-AZ60 reappearing as an An12 and confusing me.
I now remember what happened...my computer crashed and I lost all my updates from Nov 2008 to mid 2010, and when I reloaded the CD onto the new computer, the old info came up from the original AirNav db which was years out of date and showed the original 4K-AZ60 An12 as being 60083D! I then found out how to save my database regularly to avoid any future crashes wiping out my personal updates.
X
406CE0 with a flight ID of GCGKR isn't populating.
Hi Rod,
It is miscoding, G-CGKR should be showing 4060E0.  Its a Grob G 115E, c/n 82317/E of Babcock Aerospace
X
Andrew or Alan (welcome back)
7100A7 SVA9018 HZ-ASL A321-211  Saudi Arabian Airlines  4838
X
orkney
Hello X
Alan has done this one I notice. I think he is taking over again just now.
Thank you
Andrew
Hi X,
Are you connected to the network.  Unknowns should update themselves when the info is in the d/b.  HZ-ASL was added at 1318 so should have downloaded if you clicked on it.
X
I must have a problem or delay as this is the second one that did not populate when I went on network in last 24 hours and has happened previously, happened yesterday with VQ-BVQ which Andrew advised was in but was not populating my end but did after about 30 minutes or so. Is there a time lag between you inputting on d/b or is it immediate?
I am still concerned about staying on network for more than 15 minutes at a time on as it stops my hardware working after a certain amount of time.
X
