X
Andrew
Another Lump miscoding on yet another Haj flight! FAA have nothing on N744AR at present so one must assume YI-AQQ is using old code as it should be pinging 728631!
AA0176 YI-AQQ B744 Boeing 747-446 Iraqi Airways (miscode) c/n 27099/1031
X
orkney
Hello X
That one is in now also.
Thank you
Andrew
X
Andrew
Another miscode in SHJ
AA5F8C  HS-JAD B762  Boeing 767-246 c/n 23214/122 miscoding using old hex AA5F8C of N768DA.
X
orkney
Hello X
That is now in also.
Thank you once again.
Andrew
X
#1849
Andrew
This one is missing from new d/b previously EK-76021 and uses same hex first noted Jan 2010 l/n 29/9/11.
60002E EK76921 IL76 Ilyushin Il-76MD V Bird Avia opb Skiva Air 00634 67021
Think this weekend I will have to through all 76's I had in my old d/b!
x
orkney
Hello X
That one is now amended.
Thank you
Andrew
X
#1851
Andrew
Another local 76 to update/amend
152BD2 EK76155 IL76 Ilyushin Il-76T  Phoenix Avia (miscode of RA-76754/ex EK-76754) c/n 0934 21637
Warned you these pesky Russki's are a pain in the proverbial!
More unknowns from Haj land
0640E1
0640BB       B742  Kabo Air (rptd without type yesterday)
0640D4       B743
40139D       Chopper?
Network
E484F9 GOL1919
X
orkney
Hello X
That Il-76 is done now as well and E484F9 is added.
40139D was the code for G-XTRM but G-XTRM is now N923RH.
I cannot find Registrations for your other unknowns.
Thank you again
Andrew
Chris11
A63F50  N501T - Company missing Sand Castle Properties LLC
orkney
Hello Chris
That has been added
Thank you
Andrew
tommyg
Hi Guys.
While sitting here at DFW, i've noticed all the American Eagle ATR's are showing on my RB as AT75's should they not be AT72's ?
tommyg
Tommyg
ACW367
Quote from: X on October 13, 2011, 05:13:43 AM
Andrew
0640E1
0640D4       B743
40139D       Chopper?
X
X
The Nigerian CAA have restricted the following airlines to carrying Hajj passengers:
Max Airline, MedView Airline, Kabo Air, Meridian Airline and Trade Craft Nigeria Limited
This may help you to narrow the search as to which aircraft match the Nigerian Hexes. The following are the list of RVSM approved airliners for those airlines (which usually signifys Mode S fitment).
B743 5N-DBM Max Air NGL Yes 06/07/2010 Nigeria
B743 5N-BMG Max Air NGL Yes 06/07/2010 Nigeria
B743 5N-MBB Max Air NGL Yes 06/07/2010 Nigeria
B743 5N-DDK Max Air NGL Yes 06/07/2010 Nigeria
B742 5N-MAD Kabo Air QNK Yes 19/04/2011 Nigeria
B742 5N-DKB Kabo Air QNK Yes 19/04/2011 Nigeria
B742 5N-JRM Kabo Air QNK Yes 19/04/2011 Nigeria
Tommy,
ATR 72-212A have the ICAO code of AT75
tommyg
Alan.
Thnx, Airframes.org shows them as AT72, hence the query.
Tommyg
Tommyg
X
ACW367
Thanks for that I believe I have codes for all but three and I have three missing 5N- B747's, will look closely at the different variations 200/300/400 and might be able to work them out.
Looks like I'll have a busy weekend sorting out Lumps and 76's
X
