X
#2370
John
Did not look for A6-ABC at SHJ today.
Last time I noted A6-ABC flying was 6th Sep (however I was out for a few days in Sep), but that might fit with sighting of A6-RKC in full RAK c/s at ADAT AUH two weeks ago.
8960FF  ABY0997                  A6-ABC  A320  Air Arabia           2011/09/06 03:59:17
Time will tell, but ER-AXP disappeared at 0500 1/11/11 and 896336 (A6-RKC) turned up lunchtime 1/11/11 explaining initial speculation, but that turned out to be wrong.
X
ACW367
Quote from: X on November 04, 2011, 07:52:27 PM
Andrew
Possibly you are right, but the ASCT call sign and steady f/l level made it appear more like a C130. Never seen a RAF TOR ping over here in over three years.
X
RAF Tornado always use RFR (radio C/S RAFAIR) when they transit, rather then the RRR (ASCOT) callsign used by the RAF Air Transport fleet.
Morning, some unknowns from yesterday:
3D43C0 D-EXXG A210 Aquila Aviation Aquila AT01 SFC Melle - Grönegau e.V.  CN:? ( source: http://www.flugplatz-melle.de/Motorflug/Motorflug_Flugzeugpark.php )
3FF061 D-MSAG GYRO AutoGyro GmbH MT 03 (july 2010) / AutoGyro Europe MTO Sport (september 2010) AC: Private or AutoGyro GmbH CN:? (Mk1EB: By me Yesterday Afternoon. I was outside in the garden and it was flying over at low altitude, so I could see the registration and can confirm that it is still an AutoGyro. Maybe it is a test-registration of AutoGyro GmbH... / http://osc.messe-friedrichshafen.de/osc/servlet/rubin.osc.bis.BisServlet?fkCbWnr=20653070&ishop_id=AERO11_BIS_OL&vs=1&t=0628211742&altIsvlIntId=BIS_SEARCH_FL&act=showdata&ipaekopfExtid=S-38226)
3D2AED D-EOMV C172 Cessna 172S Skyhawk SP Private CN:? (Mk1EB: September 9th 2011 / http://www.planepictures.net/netshow.php?id=1086540 )
3E6248 D-KCKM AS20 Schleicher ASW-20CL Private 20727 (Mk1EB: http://www.abpic.co.uk/photo/1291650/ )
That's all.
X
#2373
I believe one of my unknown Yank Herc's (probably an AC-130U) is now over here!
* AE12A9  RCH1004                                                     2011/11/06 04:07:09
Could fit unknown 90-0165, was at steady f/l 150 eastbound for ten minutes.
X
X
A71312 N555MA, Stoddard-Hamilton Glasair IIS, c/n 2099, Mary B Alexander
X
#2375
Quote from: John Hargreaves on November 05, 2011, 09:59:29 PM
X
With regard to the new RAK A320 A6-RKC, do you know if A6-ABC is still stored at Sharjah? Have seen it mentioned (may not necessarily be true) that RAK were taking a 'surplus' Air Arabia frame.
John H.
John
A6-ABC last noted SHJ all white 19/10/11
X
Thanks Ingo,
3FF061 D-MSAG Autogyro MTOsport c/n unknown
3D2AED D-EOMV c/n 172S9076
X
The Herc Hex IS unknown  to me
For your info Skyliner has ER-AXP as ferried 03nov11 RKT-BUD after lease to RAK Airways
X
noticed new db has HZ-AS11 and 12 as Saudi Special Flight Services rather than Saudi Arabian Airlines
X
Chris11
00DDEB ZU-JOC - RV10   Van's Aircraft RV10   PHARMACEUTICAL CONTRACTORS (PTY) LTD c/n41088
#2380
Thanks Chris,
HZ-AS11 and 12 have been that way since 6/4/2010, now changed
The RV-10 is already in the d/b as you detail
X
Been looking at Qatar Airways in new db, and seems some minor changes are needed.
Some Qatar Amiri Flight a/c (as I call it) show as Qatar Airways others as Qatar Government Amiri flight. I know many carry full Qatar Airways c/s and this is probably confusing to people who do not live out here. e.g. A7-AAH A340 and minibuses A7-MBK/MED/MHH are all Amiri a/c as are the A7-H.. series airliners. Very occasionally some turn up on scheduled flights, but it is rare.
Some A7-CE biz jets show as Qatar Airways some as Qatar Executive.
X
X
I believe all Saudi bizjets HZ-SPAA through HZ-SPAL should now carry Saudi Private Aviation (SPA) as operator.
X
54901 - Jim
Good morning, Alan!
Any info for C2B0CB?
It's on my log this morning.
Thanks!
KOSH - Oshkosh, Wisconsin USA
X
7610D6 not in db.... I think is Pakistan C130 that has landed in sandpit....Don't tell me I have to go down and read it off!
X
