shouriken
New Spartan for the Romanian Air Force:
4A35AC - 2703 - C27J - Alenia C-27J Spartan - Romania - Air Force - 4156
Liviu
Liviu
A.net JetPhotos.Net
RadarBox
#661
X
The d/b with your box should have the following
42418A, VP-CQY, Embraer E190-100LR, c/n 19000227
42419D, VP-CXU, Airbus A320-214, c/n 2123
They have been in the d/b as such until this morning when you asked about 42418A.  A check of your Navdata using database explorer will show this and also show they were correct when you asked the question
When you asked I looked at the database that I use and it gave 42418A as A320 VP-CXU and I checked with Airframes which gives the same and also gives 42419D as VP-CQY as does my database.  GAS does not have any entries against either of these aircraft.
Further a query against 42418a on the mode-s forum shows on a SBS-1 report from Riyadh on 18/3
42418A -------- VP-CXU   A320 ----- ----- 18/03/2011 12:54:25
42418A -------- VP-CXU   A320 ----- ----- 18/03/2011 14:44:32
42418A KNE786   VP-CXU   A320 11550 9600  18/03/2011 18:48:08
42418A -------- VP-CXU   A320 ----- ----- 18/03/2011 20:26:58
42418A -------- VP-CXU   A320 ----- ----- 18/03/2011 23:53:26
and
42419D -------- VP-CQY   E190 3200  3650  18/03/2011 12:37:06
This lead me to believe that the Navdata entries for these 2 aircraft were incorrect and I changed them.
Given the information you have provided I will return them to their previous conditions.
E190's tend to be Embraers and it is definatly VP-CQY and not VP-CQY as per your last reply.
Thanks Liviu, much appreciated.
X
#664
Thanks now I am happy that my box was correct and my eyesight was not deteriorating to the point I cannot differentiate between a A320 and E190, however a little confused over last sentence as I trust E190's tend to be Embraers and that we agree VP-CQY is what I saw!
"E190's tend to be Embraers and it is definately VP-CQY and not VP-CQY as per your last reply."
Anyway I trust that we have resolved that issue finally
PS whoever was in Riyadh obviously does suffer from the inability to differentiate between an A320 and an E190!!!.. the eyeball thing you mentioned yesterday
Thanks for your help
X
X
#665
PS better inform Airframes etc that Mr Riyadh has screwed up their db or others may get wrong info
X
54901 - Jim
Another one for you, Alan:
A36039 / N3165Y / C182 / Cessna 182E / Foster John W / 18254165
Thanks!
KOSH - Oshkosh, Wisconsin USA
X
Usual unknowns for UAE (you have searched already)
0467F0                                                              2011/07/23 05:30:28
AE1D1B                                                              2011/07/23 05:57:48
X
X
#668
New one to the area
* 0467F9                                                              2011/07/25 01:15:27
* 0467F9                                                              2011/07/25 06:04:36
X
Morning, here are the unknowns from Sunday:
461202 (Finland)
484157 (Netherlands)
The rest are known unknowns with no new information and/or MIL-TACTICAL's.
X
100% confirmed 728002 is YI-AQB
"IA107/108 14th Feb was YI-AQB arr around 1255"
728001 also 100% YI-AQA
X
X
E80313  SKU4306 not populating
X
X
Sqeezyjet on Network showing Mode S as EZY89W fl id EZY89WF!!!!
That must be a serious case of Pilot error...never noted that before!
X
X
Here is a list of Soviet UAE tie ups I have either seen or looked into so NOT 100% but might give some missing info/ideas to help you.
018022   5A-DQA   IL76
046769   3X-GFK   IL76   Air Guinea
0467D2   3X-GFR   IL76   Air Guinea
0467F0   3X-GGO?   IL76   Air Guinea
0467F9   3X-
07C03C   ST-BDN   IL76   Badr Airlines          Now ST-BDR?
152A5D   RA-76381   IL76   Tesis
156ADD   UP-I7641   IL76                              Old RA- miscode ex RA-76509
152BFF   RA-76799   IL76   Operator unknown      Russian Sky c/s
152C0C   EK-76812   IL76   Veteran                   Old RA-code still being used
4C0189   UP-I7626   IL76   Operator unknown   Old code of YU-AMJ
508058   UR-78785   IL76   Yuzmashavia
508059   UR-78786   IL76   Yuzmashavia
50808B   EK-76592   IL76   ex UR-76778/EK-76737 Old UR- code still being used
51401C   4L-GLM   IL76   Sakaviaservice
51401D   4L-
514024   4L-
514025   4L-GLP   IL76   Sakaviaservice
514030   4L-GLK   IL76   Sakaviaservice
514031   4L-GLR   IL76   Sakaviaservice
514033   4L-FFG   IL76   Eastern Express
514034   4L-           IL76   Operator unknown basic SU c/s
514035   4L-           IL76   Operator unknown
51403B   4L-GLX   IL76   Sakaviaservice
514040   4L-MGC   IL76   Sun Way   W/O Karachi
514045   4L-SKY   IL76   Sky Georgia
514053   4L-SKD   IL76   Sky Georgia
60001E   EK-76292   IL76   Rus Aviation
600050   EK-           IL76
60005C   EK-76485   IL76   Rus Aviation
60005F   EK-           IL76
600061   EK-76643   IL76   Taron Avia
600065   EK-76640   IL76   Ark Airways
600068   UP-I7638   IL76   Now 4L-SKY
60006A   EK-
60006C   EK-           IL76
600073   EK-76808   IL76   Rus Aviation
603007              IL76                                          Wrong code 683007?
6030A0              IL76   Operator unknown all white c/sWrong code 6830A0?
601055   EY-           IL76   Operator unknown
601066   4L-GLM   IL76   Operator unknown all white c/s Using old EX- Mode S
601066   4L-GLP   IL76   Operator unknown all white c/s Using old EX- Mode S
601067   EX-035   IL76   Operator unknown all white c/s
601084   EY-602   IL76   Operator unknown all white c/s
683009   UP-I7606   IL76
683024   UN-76006   IL76   now UP-I7621   Miscode
683047
68305B   EK-76111   IL76   Rus Aviation
683075   UP-I7625   IL76   A400 c/s
683089   UP-I7621   IL76
683091
6830A7   UP-I7602   IL76   Air Almaty
708047   YA-KAN   IL76   Operator n/n grey tail Old mode S of RDPL-34146
           4L-FFF   IL76   Eastern Express
           4L-FFE   IL76   Eastern Express
           4L-GLL   IL76   Sakaviaservice   Now EK-76808 600073
60104C   EK-12704   AN12   Operator unknown
X
