Morning Ingo,
461202, OH-GVI, Canadair CL-600-2B16 Challenger 605, Jetflite OY
484157 unknown as yet.
X
The ones previously looked at are still unknown
0467F9 unknown to me
E80313 Sky Airlines Chile unknown
Note the confirmation on the CRJ9's
I will have alook at your large list when I get a minute later this morning
x
5A-DQA is now EK76425, Ilyishin Il-76TD, 1003405167, RUS Aviation
046769 3X-GFK. Il-76MD c/n 0073475268, GR Avia
0467D2, Il-76MD, c/n 0063471150, GR Avia
I stil lahve ST-BDN as an Il-76, I have ST-BDR as a MIL-8 HIP
RA-76381 is now EK76381, c/n 1033418596, Il-76TD Veteran Avia
156ADD de-codes to RA-92893 unknown.  UP-I7641, Il-76T, c/n 083413415
152BFF is in the d/b
152C0C is in the d/b
4C0189 UP-I7626, Il-76TD, c/n 1013409303, Beibars JSC
508058 is in the d/b
508059 is in the d/b
50808B, EK76592, Il-76MD, c/n 0083483502, V Bird Avia
All the  Sakaviaservice  are showing as cancelled as they have went out of business
51401D, 514024, 514034, 514035 unknown to me
4L-FFG showing as cancelled
514045 4L-SKY in d/b
514053 4L-SKD in d/b
600001 EK-76643 in d/b
600050 unknown to me
60005C EK-76485 in d/b
60005F unknown to me
600061 is in the d/b
600065 is in the d/b
60006A unknown to me
60006C unknown to me
600073 is in the d/b
603007 and 6030A0 both unknown to me and as you state miscodes
601055 unknown to me
601066 was 4L-GLP cancelled
601084 EK76808, Il-76TD, c/n 1013405177, RUS Aviation
683009 UP-I7616, Il-76TD, c/n 1033416515, Sayakhat in the d/b miscode
682024 UP-I7621, Il-76TD, c/n 001343018, East Wing miscode
683091 unknown to me
6830A7 UP-I7602, Il-76TD, c/n 0003427796, Air Almaty in the d/d miscode
708047 YA-KAN is in the d/b
4L-FFF and 4L-FFE both unknown to me
60104C EK12704, Antonov An-12B, 01347704, Taron Avia
X
I just realised I had forgotten to update two in this list and had already tied them up. Both you note above as unknown to you and were miscodes
603007   UP-I7634   IL76
6030A0   UP-I7612   IL76
Probably poled off at a later date and entered them in my db but not deleted as unknowns
X
X
6830A0 UP-I7612, Ilyushin Il-76T, 0003425746, Eastern Express
683007 was UP-I7634 and is now EK76442, Ilyushin IL-76, c/n 1023414450, Pheonix Avia and is in the d/b as 603007 showing as a miscode in addition to an entey using the correct code.
X
#680
Thanks for the hard work you must have done on this.
ST-BDN going ST-BDR had concerned me so I had a BIG question mark against it....bad report from somewhere!
This file was made over a period of three 1/2 years and I am aware that many have now changed hands/regs etc, but I keep record of last used Mode S just in case they do not change (as is so often the case) and when they reappear with a new reg I work (or at least try) on new codes with some friends. When I eyeball I try to get reg and t/s but many are just basic SU or all white!
They are an absolute pain in the a** to keep up with but keeps us on our toes out here between the daily monotony of EK/FD/QR etc!
X
54901 - Jim
Missing today:
ACF551 / N934JD / C310 / Cessna T310R / Wichita Air Services Leasing LLC / 310R1002
Thanks!
KOSH - Oshkosh, Wisconsin USA
X
E48A05 fl id PRASM not populating
x
X
#684
I appear not to have a code for 4L-SKN IL76
X
X
#685
Same unknowns from Gulf
   0467F0                                                              2011/07/25 04:14:09
* 0467F9                                                              2011/07/25 01:15:27
* 0467F9                                                              2011/07/25 06:04:36
   60005F                                   IL76                     2011/07/25 17:13:59
   60005F                                   IL76                     2011/07/25 21:23:00
   60006C                                  IL76                      2011/07/25 06:48:40
   60006C                                  IL76                      2011/07/25 10:30:13
Got to go down to the new JXB/DWC one day and tie them up as either they are too far away to pole off or its too dark!
X
X
* 01009D                                                              2011/07/26 08:13:04
Climbed to 19000 before timeout
X
X
* A7CABE                                                              2011/07/26 08:44:19
Constant 2250ft
X
Morning X
Only one I have any info on is A7CABE.  Formerly N6008Q Air Tractor AT-802 c/n 802-4006 became A6-*** earlier this year.
I can get everything on 4L-SKN apart from its hex
It lOoks like you will have to take your box out in the car and get these.
X
#689
Picked these up at ZRH in March, most probably all ground stuff rather than A/C so i had not put them in my missing codes files
* 480001  REGA7                                                         2011/03/30 19:23:20
* 4B5C1A  GUSTI2                                                       2011/03/30 20:14:28
* 4B5C1B  URSULA8                                                     2011/03/30 22:00:57
* 4B5C1D  ZEBRA1                                                      2011/03/30 20:16:17
* 4B5C20  ZEBRA7                                                      2011/03/30 19:06:39
* 4B5C4E  FLORI221                                                    2011/03/30 23:13:17
* 4B5C60  FLORI568                                                    2011/03/30 19:27:08
* 4B5C65  ORION1                                                      2011/03/30 19:19:39
* 4B5C67  FLORI225                                                    2011/03/30 23:12:50
* 4B5C27  EUGEN11                                                     2011/03/31 03:57:31
* 4B5C50  FLORI223                                                    2011/03/31 05:43:41
* 4B5C1E  ZEBRA2                                                      2011/03/21 18:22:50
* 4B5C21  ZEBRA8                                                      2011/03/21 18:30:05
* 4B5CCD  TEST1234                                                    2011/03/21 18:13:53
* 4B5CCE  TEST1234                                                    2011/03/21 18:13:56
* 4B5CCF  TEST1234                                                    2011/03/21 18:13:56
* 4B5CD0  TEST1234                                                    2011/03/21 18:13:56
X
