Outlines
Started by RodBearden, April 06, 2012, 03:04:45 PM
Thanks Rod,
Lots of UTAir and Transaero aircraft currently in storage there.
A new outline for an Indiana airport:
South Bend International - KSBN
New Florida outline:
Florida Keys Marathon - KMTH
rsgomes
Hi Rod Bearden. Do you have any special software for to make the Outlines? Thanks in advance.
Ricardo Gomes
Possibly Rod is using this http://acme.com/jef/outlines/ or another similar website.
Ricardo,
If you have any special requests for outlines, please advise Rod and I am sure he will oblige
Hi Ricardo
Yes, I do use the website that Ingo refers to - Jordan's Outliner, and as Alan says, I'm open to do requests. If you want to do outlines yourself, I do have instructions on how to do them - let me know, and I'll try to find them.
FACTflights
Hi Rod,
Would this work to produce adjustable range rings ?
John
ZS1AGH
No HF antennae at the moment.
Hi John
You might be able to produce fixed range rings, but it wouldn't be an easy task. So basically the answer is no.
FACTflights
Rod,
OK, I acually meant to adjust the radar rings that are already there or produce new ones in a different cdolour that make more sence than 78.2 nm.  Sometning like 5 ; 10; 20 ; etc; 100nm; and so on.
John
ZS1AGH
I don't know of any way to change the rings we already have.
rsgomes
Thank you for all the replies. I already use Jordan's Outlines website to make Faro Airport (LPFR) updated outlines. Regards.
OK rsgomes - if you want to share your updated outline, you are very welcome to post it here...
rsgomes
#508
Here are. The lpfr.out has some outlines made by Rod Bearden :) Runway, Terminal, Airbridges and other buildings.
Faro Airport (FAO/LPFR)
Many thanks for those rsgomes - they replace the old Faro Portugal LPFR.out file.
