Network Server - Update
Started by AirNav Development, January 06, 2013, 05:26:54 AM
paulfineman
Alan what do you think has happened
It's seemed positive yesterday
I know there doing there best
Paul
paul mar fineman
flygfantast
I still get the "blank" images and I analyzed the HTTP-post to the servers, it looks like this:
Node 1: IP = xxx.xxx.x.xxx, TCP port = 4918
Node 2: IP = 96.31.64.2, TCP port = 80
GET /cgi-bin/ANLV_SV/ANLV_SV_user.exe?usgetphoto=0&usverify_name=PGANRBxxxxxx&usversion=ANRB403&regsearch=SE-ISY&modes=4A8130 HTTP/1.1
Content-Type: text/html
Host: www.airnavsystems.com
Accept: text/html, */*
User-Agent: Mozilla/3.0 (compatible; Indy Library)
HTTP/1.1 200 OK
Date: Sat, 02 Feb 2013 11:46:42 GMT
Server: Apache/2.2.23 (Win32) PHP/5.3.20
Content-Length: 395
<ANLVStart>OK;http://www.airnavsystems.com/cgi-bin/ANLV_SV/Photo/SE-ISY-1B1PIGHNSR.jpg;340A-080;Saab 340A(QC);NextJet;Lars Baek;http://www.planespotters.net/Aviation_Photos/photo.show?id=131709&source=rb24;SE-ISY;OK;http://www.airnavsystems.com/cgi-bin/ANLV_SV/Photo/SE-ISY-53TZRT6TQ1.jpg;340A-080;Saab 340A(QC);NextJet;Planespotters.net;http://www.planespotters.net/&source=rb24;SE-ISY<ANLVEnd>
Now checking the URL given i the HTTP-post gives this:
http://www.airnavsystems.com/cgi-bin/ANLV_SV/Photo/SE-ISY-1B1PIGHNSR.jpg -> blank image
http://www.airnavsystems.com/cgi-bin/ANLV_SV/Photo/SE-ISY-53TZRT6TQ1.jpg -> blank image
http://www.airnavsystems.com/cgi-bin/ANLV_SV/Photo/SE-ISY.jpg -> gives a correct image
http://www.planespotters.net/Aviation_Photos/photo.show?id=131709&source=rb24 [correct URL]
http://www.planespotters.net/&source=rb24 [incorrect URL (Error 404), although it's in the NAVDATA-db that way]
Just a reflection, maybe it can bring some light to the problem...
Niklas
Cable: Ecoflex-10 (10m+1m)
Havent a clue Paul, all I know is that they are working on it and when they have it sorted we will be advised.
I have forward your post to Airnav Niklas
flygfantast
Done some more digging on the "blank" image problem and it seems to be related to entries in the NAVDATA d/b.
The one thing in common on the aircraft that have "blank" images downloaded is that one or both photolinks is
"incorrect", i.e. it has a link like "http://www.planespotters.net/" or "http://www.planespotters.net/&source=rb24".
Aircraft with both links correct is downloaded properly.
So a cleanup of incorrect LK & LK2 entries in the aircraft table are needed.
Niklas
Thank goodness we cant do them!!  I would imaging the 2nd one should put up a *Photo Not Available"
flygfantast
Quote from: Runway 31Thank goodness we cant do them!!  I would imaging the 2nd one should put up a *Photo Not Available"
Something must have went wrong on the migration from airliners.net -> planespotters.net. I see several entries in the aircraft table that have column LK/LK2 as "http://www.planespotters.net/" or "http://www.planespotters.net/&source=rb24". These field should be "blanked" out. Being a programmer myself and using databases in my work, this seems to me like a "one-liner" of code for Airnav to fix on the central server (where I image the NAVDATA d/b is built from). If these incorrect field values are corrected then no image will download and the program will automatically show "Photo not available". :-)
Ps. Alan I  think you missed my entry regarding 3964E6 in the database update request thread Ds.
Niklas
Niklas
Forwarded your coments onto Dev to ensure he sees them as he is busy with the servers.
Niklas,
How did you get the quotes tab to work ?
See the other thread !
flygfantast
EK01,
I added the tags manually: [ quote="name" ] quoted text [ /quote ]
The extra spaces before/after the [] chars must be removed, had to add them so I can show them here.
Niklas
paulfineman
Good morning airnav systems would
You be so kind to let us know about
The progress being made on radar box
Alerts sorry to be a pain
Paul
paul mar fineman
Thanks Niklas. Bit too advanced for me !
Regarding this one I would kindly ask for all the users that still don't receive email alerts, to send us a PM to "AirNav Development" with your email address / the email you are using to send alerts to (we will use this to test the new procedures we are developing).
paulfineman
Hi airnav devlopment still no alerts my email is
Paul
paul mar fineman
