Network Server - Update
Started by AirNav Development, January 06, 2013, 05:26:54 AM
As mentioned above in Devs post, we don't want to do that at this stage, we would idealy like to rectify the server and release a new version later with the various changes that have been tested.
mista uzi
Guess what.  Ideally we would like you to fix the problem.  In my opinion your product and more so your support and ability to service your customers is becoming just a joke.
About time you came clean to the extent of the issue and provide your CUSTOMERS the common courtesy and provide us, YOUR CUSTOMERS a timeline to a resolution.  Enough of the lame excuses..
If you cant fix your problem then about time you seriously thought about releasing a suitable and workable workaround.
We have, finally, good news.
After a long battle with software development companies that we use on our server we found a solution for the bug that caused the Alert feature not to work properly.
We are testing it on our secondary server and if all goes OK we will have the alert feature ready withing 24 hours.
Tks again for all your patience with this issue.
We will bring the server down for 1 hour to apply the latest updates and hopefully have the alert feature problem corrected.
Have you also fixed the problem with regard to blank thumbnails of aircraft being downloaded ? As of now ,it's still happening !
paulfineman
Great newa my alerts working
Paul
paul mar fineman
janssen1980
Alers here also working again. Thanks Aurnav for all the hard work
I can't believe it, I've received some alerts!
Hope it stays that way.
We really apologize for the long delay in correcting this problem. We don't want to enter any technical details here but it was a long story. Fortunately all OK now. We will now focus on all the other pending items.
paulfineman
Dear airnav well done all going well so far
Paul in kent
paul mar fineman
Only half solved so far...
Alerts are only working with my yahoo mail address, but not with my aol mail.
Hi Ingo, I've vague recollections of there being problems a long time back with AOL and auto messages - can anyone remember more than me?
N9JIG
Thanks, I can also confirm it is working now. I appreciate all the work involved in fixing this!
I would like to suggest as a feature for the next version of the user application (or a service pack...) that you allow a user to use his own mail server if they have one. Perhaps a simple check box with the default to use your server and if the box is checked the user is prompted to enter his mail server info.
This might reduce the load on your server somewhat as well as allowing those of us with the resources and know-how to bypass your server.
#268
QuoteHi Ingo, I've vague recollections of there being problems a long time back with AOL and auto messages - can anyone remember more than me?
Maybe, but Alert and Log sending to Aol was working before the big crash. On the other hand, that's the reason why l have concidered to use two mail addresses in the first place.
As for the daily Log I've established a daily routine using my remote access. But anyway it would be great, if it will work with all Mail addresses again.
Great to see Airnav reports once again on the mode-s forum
