Network Server - Update
Started by AirNav Development, January 06, 2013, 05:26:54 AM
orkney
Hello Airnav
Our first log and alert emails since the 5th of January have now come.  Many thanks for getting it fixed.
Andrew
Alert ratio from today morning until now:
RB Software generated 21 Alerts. Received: 11 Alert-Mails. --> 52% of generated alerts were received
shouriken
Log email is working here, but the forum notifications still don't.
Liviu
Liviu
A.net JetPhotos.Net
RadarBox
vaca05
Log email is not working for me. I have hotmail.
vaca05
Sorry meant to say alert email is not working for me. I use hotmail
mikek
vaca05. I use hotmail also and the log emails are heading into my 'junk' mail box. This used to happen a bit too, but I suspect if you mark it as not junk they will eventually come through into your normal inbox once hotmail realises they aren't 'suspect'.
Hope thats the case for you too...
Mike
The problem regarding blank thumbnails being downloaded has been corrected.  Can you check and ensure this is the case please.
Seems ok at the moment Alan but have only just switched on. Will continue to monitor .
vaca05
Thanks Mike checked the junk folder and there they are.
Larry
Bat 21
Blank thumbnail probelem seem all sorted for me !
Thanks for fixing it
Bat 21
Thanks for the confirmation Bat 21
Alan,
Had some newbies on today and can confirm that instead of blank thumbnails appearing which was the case before, picture ones now seem to be downloading ok.
Cheers Ian, will pass this one
YXUphoto
I have over 3400 blank photos now....not good!!
Is there a quick way I can get those photos back if I know what the REGes are?
(have a list)
