Author Topic: Hardware not connected  (Read 16466 times)
Harry
« on: July 07, 2007, 06:51:27 AM »
Received the box yesterday. I keep running into the following problem: after a while I get the following message: Hardware not connected. I have to restart the program. The only way to restart is via the taskmanager, because the file exit doesn't work.
So, basically two problems: 1 after a while the message hardware not connected and 2 I cannot exit the program normally.
I'm running XP sp2 1024mb memory and 190GB harddisk with 150gb of free space.
Harry
mt007
    • Super Сasual Dating - Real-life Girls
Re: Hardware not connected
« Reply #1 on: July 07, 2007, 07:00:37 AM »
Hi Harry,
i suppose do you have install radarbox program and drives first and then you have connected to the computer, is correct?
Best regards.
« Last Edit: July 07, 2007, 07:02:26 AM by mt007 »
Harry
« Reply #2 on: July 07, 2007, 08:24:02 AM »
Hi Miguel,
I did it the otherway around.  (as on the quick install quide) First the hardware and then the software.
harry
Hi Harry,
Best regards.
mt007
« Reply #3 on: July 07, 2007, 08:36:25 AM »
i think the problem is about drivers, try unistall and install again.
CanadaKen
« Reply #4 on: July 07, 2007, 02:16:17 PM »
harry
I think that's your problem, Harry. I saw it mentioned here already....the Quick Install is wrong.
Like 99% of USB applications you install the software first....BEFORE you plug the hardware into the USB port.
CK
Monitoring on Canada's "Left" coast
Harry
« Reply #5 on: July 07, 2007, 05:54:21 PM »
Hi CK and others,
I reinstalled the drivers and software for the third time and I don't see any improvement. Any other suggestions?
Harry
harry
CK
CanadaKen
« Reply #6 on: July 07, 2007, 05:59:55 PM »
Just off the top of my head I would say AirNav Support will have to give you instructions on
how to remove all Windows Registry references to the RadarBox software.
CK
« Reply #7 on: July 07, 2007, 06:42:42 PM »
Harry contact support through our website or our email and they will tell you some items to test.
