Started by orkney, March 19, 2013, 03:11:01 PM
X
This does not look right unless via OMAD
ETD454  LFPG-YSSY?????
X
No X its should be OMAA-YSSY now amended back to this,  It was amended by the auto routine and I bet the previous flight of the aircraft was from LFPG to OMAA and the server look up hasnt released the previous route.
superspotter
#482
One more from Lagos before my bed beckons: Hexcode 06406F is 5N-JNR Allied Cargo 727F DHL colours, recited registration upon landing, As a footnote; on this trip I have brought an outside antenna with me for the scanner hoping that it would better my reception in order to hear the aircraft call their registrations as they are compelled to do here. It is doing the job so hopefully I may be able to tie a few more up in the coming fortnight that I am here,  regards clive.
Thanks Clive look forward to hearing from you
CYYZGUY
Hi Alan, can you check this one please.  I am pretty sure its wrong.
ACA1128
Showing CYQR-CYYZ
Flightaware shows CYYC-CYYZ
regards,
40" LED Monitor
40" LED Monitor
vaca05
Hi Alan
UAL 1509 was listed as KPHL-LIAH-MGGT
Checked on Flightaware it is KLAX-KDEN
Larry
vaca05
Sorry Alan,
I found another one.
UAL 439 is listed as KDEN-KEWR
It is actually KSFO-KLAX
larry
X
2298 is the reg of the AT-802 UAE Air Force ex N2086C
X
Hi vac05,
Unfortunately United use the same flight ID for different routes dependent on the day of the week, some ID's can be used up to 3 times per week on different routes.
UAL439 today routes KSEA-KSFO-KLAX-KDEN as it did yesterday, other days its different. Have a look at http://uk.flightaware.com/live/flight/UAL439 and see the different routing with this flight ID
UAL1509 was as you state on KLAX-KDEN yesterday, today it is KBOS-KIAH-MGGT again flight aware shows routes http://uk.flightaware.com/live/flight/UAL1509
It doesnt matter what route I base it on some will be wrong at different times in the week unfortunately.
Thanks X, added in c/n 802-4019
Alan,
Apologies for the late response but the heat here makes you sleepy as you will soon find out ! Can confirm , however, that CFE31B definately landed as such at Malaga from London City.
Thanks Ian,
I have received an update to CFE flights and added them in this morning, quite a few changes ,CFE31B is now the inbound Malaga flight from London City as you stated.
Its positively troplical here today up to 8 degrees!!
Out of XFW as GOW9007 is 8007D0  VT-GOM  A320-214  c/n 5552  Go Air
Thanks John
