Started by orkney, March 19, 2013, 03:11:01 PM
X
#511
Hi Jason,
This is because we dont know what it is and it isnt in the database. A posting on the mode_s forum detailed its hex as 503DA6 but no one knows any other details, do you have its registration?  Flightaware details the flight as being operated by an A319 but that is all that is known about it at this time although there is a possibility it could be LY-VET but no confirmation.
Northern Watch
Good evening Alan
A couple of aircraft that did not populate today:
A40EBA / N3600X / Cirrus SR22T / c/n 491 / owner Cirrus Design on delivery?
AE1CFB believe this to be a P-3C Orion possibly 158224 of USA other P-3's movement in the North today.
Keith
Thanks again,
Keith,
I saw the SR22T on the network earlier and added it in.
AE1CFB, 158224, Lockheed P-3C Orions c/n5569, US - Navy
Morning Alan,
In d/b SIA68 shows as routing VHHH-SBGR. It should be LEBL-SBGR which incidentally it used to show.
Hi Ian,
Automatics at it again no w corrected to show SIA68,WSSS,SBGR,LEBL,
Alan,
Another one for you :
RYR7713 in d/b as EKAH-EGSS, should be GMFF-EDLV.
Cheers Ian,
There was actually no route showing in the server d/b as the automatics added in the wrong route and then deleted it as its wrong!!
CYYZGUY,
503DA6, LY-VET, Airbus A319-112, c/n 1778, Avion Express /Cubana now confirmed and in d/b so will populate if you click on it next time seen.
Michel
Alan,
I found out what was wrong with my THY flight ID's. Routing of THY1MY is LTAC-EHAM iso LTBA-EHAM. The other THY flight to/from EHAM use their flightnumber as callsign.
I Also discovered I missed some FlyBe ID's:
BEE1PE EGHI-EHAM
BEE8EL EHAM-EGHI
BEE2PF EGBB-EHAM
BEE6BV EHAM-EGBB
BEE4PH EHAM-EGBB
BEE3JY EGBB-EHAM
Michel.
Very much appreciated, thanks Michel.
Hi Alan
Noticed a typo:
VIR3042 should be EGCC-EGLL, not EGCD-EGLL
superspotter
Hell o from Lagos. I don't have a tie up but a request for one for a change! Hexcode 20102E looked like a Be350 or maybe even a PC-12 any ideas?
regards clive.
Thanks Rod, changed it back, sometimes the automatic route routine changes thing when the aircraft goes near Woodford, usually put s it in as ECCC-EGCD though.
Hi Clive, the only thing I can advise is that is from Namibia V5-***
