Your experience upgrading to 5.00.044
Started by Kenny, October 19, 2013, 07:05:58 AM
vonsmalhausen
oeps, rather annoying problem : no more network !
get network flights is ticked, and connection to network is green, but nothing in the grid.
Vonsmalhousen
Re Scrrenshot 2  This relates to auto-updates when the individual aircraft is received.  If the box is ticked the details will be updated to the same as the server entry.  If unticked it will not be touched.
I will forward the error with the silhoutte column header
Screenshot 4 refers to the whole databse as opposed to individual aircraft in screenshot 2
If the Navdata details are different from the server details it must have been manually updated.  If you tick or untick the boxes the tables are updated or not depending on your preferences.
The network is OK here in Spain, maybe the network went dowen for a short time?
There is something wrong with those flight ID's they are incorrect.  Is your radarbox connected directly to your computer and via anther method?
John,
In your airnav/radarbox folder above ANRB.exe you should have a file, ANRB.dat.  Let me know if you have it
jpr89
Quote from: Aerotower on October 19, 2013, 02:40:30 PM
and is very slow when I pass a plane to another in MyLog.
Same problem here, but only with "old" data (before the upgrade to v.5). When I selected an aircraft contacted yesterday for example, it's very long and Mylog "isn't responding" for about 15-30 seconds, then it's ok.
Also, all the aircraft pictures downloaded before the update aren't appearing now?!
tommyg
Downloaded and seems to be ok. The only issue I came across was I had no map at all showing (don't use 3D) and only by chance clicked on the map view button top right of screen and map appeared. Everything else ok, I can even resize the preference windows for the first time without having to use resizenable.
tommyg
Tommyg
vonsmalhausen
just restarted my system  : still no network, and I still get these "wrong" flight ID's
my box is connected true a USB Hub to my PC, ..... like it always has been
vonsmalhausen,
Something does seem wrong for your install, try backing up data and then clean the RadarBox folder and install the new full version again. Something looks like it has been corrupted.
vonsmalhausen
Hi Alan, Just done another complete shutdown and reboot, on trying to open ANRB I et a box with the message:
Cannot open file "C:\AirNav Systems\AirNav RadarBox\ANRB.dat". The system cannot find the file specified.
This would appear to confirm your suggestion, and I've not been able to locate it!
This one isn't related to Version 5 only, but does anyone else have this effect with B788s?
Alert Time: 2013.10.19 16:24:51
Received Aircraft: B788 (800734)
Received Aircraft: B788 (800734) <--
Total flight information:
Flight ID:
Registration: VT-ANN
Aircraft: B788
Routing:
Altitude: 38000
Speed:
Heading:
Hi John,
I have been trying to attach the file to the post but  for some reason I cannot get it to attach.  Send me a PM with your email and I will post it to you.   It was in an earlier post but has disappeared.
vonsmalhausen
ok, did a complete uninstall, and installed the full version instead of the upgrade, ......
still the same : no network ( the first time I launched, I was even back to delayed network ) aldo the light is green + still those long ID's for some flights
also I feel like I have a lot less "my flights" ; normally I get around 150+ hits round this time of the day/week, now "only" between 90 and 100.
really not pleased with this "update"
tomorrow i'll try to reverse back to the old version, if this is what we had to wait for the last years...........pffffffffff
Just tried to open the submenu show all photos under MyLog. There are 36471 pictures in this folder. RB Software freeced with no reaction. After a while windows stated the "no reaction" message and performed a crowbar shut down of software. After re-start all screen settings were back to condition of first start after update.
MyLog was left filled. Autopopulated airframes were still in navdatabase.
Problem is repoduceable.
