Author Topic: Your experience upgrading to 5.00.044  (Read 105647 times)
Kenny
Re: Your experience upgrading to 5.00.044
« Reply #60 on: October 19, 2013, 06:43:09 PM »
The  VTBD label on 2D map is now corrected, however, still no VTBS label (see attach).
ANRB 3km north of VTBD
vonsmalhausen
« Reply #61 on: October 19, 2013, 06:53:26 PM »
uninstalled version 5, and reinstalled version 4 : network back on again and no more strange ID's
applied the update again....... network gone again
this is defenatly a version 5 problem
« Reply #62 on: October 19, 2013, 06:58:07 PM »
I dont have anywhere near 36471 photos in my folder but it still takes a while for all my photos to open.  Even thought it showed not responding it still opened up when I just tried it, even if it took some time.  37,000 photos is a lot of data to open up and will take a while to open them all up
« Reply #63 on: October 19, 2013, 07:00:15 PM »
Is it possible, that your firewall -if you are using one- is having a problem with version 5?
Own problem:
Log and altert sending by using own mail account ist not working. Mail/alert via Server is working. Mail Account configuration in ANRB is identical to mail program. Firewall comsettings of ANRB and Mail program altered to identical settings. I gettting still the sent failed notification from ANRB software.
« Reply #64 on: October 19, 2013, 07:04:47 PM »
Kenny,
That part has not been sorted yet.
« Reply #65 on: October 19, 2013, 07:06:01 PM »
Alan,
I have the exact same problem as CoastGuardJon with the same long screed of fault messages. I also have to use the Task Manager to close the thing down. Beginning now to feel a bit like vonsmalhausen. I can't even get the original version back on.
Giving up and closing down. What a waste of time !
« Reply #66 on: October 19, 2013, 07:06:34 PM »
Ingo,
Even although your getting the sent failed notification, did the mail get sent.
« Reply #67 on: October 19, 2013, 07:07:10 PM »
Ian,
Contact me by email
« Reply #68 on: October 19, 2013, 07:08:55 PM »
Quote
This is a known fact and I gave the V5 twice the time V4 had needed to open the pictures. Maybe I should rename the folder and start with a blanc one. Last time I flushed the folder was about three years ago, so many airframe pictures will be already outdated by now too.
I have about 27000 (22000 in the past 280 days on the 24/7 box) airframes in my MyLog. Two pictures for each airframe...
« Reply #69 on: October 19, 2013, 07:11:04 PM »
Mail haven't been sent. No rise in upload traffic, No mail received with destination address. Switched back to server mode and tried again. Rise in uplaod traffic and LOG/Data received, no "sent failed" notification.
« Reply #70 on: October 19, 2013, 07:13:08 PM »
Thanks Ingo
« Reply #71 on: October 19, 2013, 07:32:08 PM »
The naming of the donwloaded photo has changed withing V5:
is it still possible to insert individual ones in the old reg / reg,2 format?
« Reply #72 on: October 19, 2013, 07:44:10 PM »
Yes Ingo,  photo's can still be added manually as before.  However I believe you have to add the aircraft registration into the PTTN and PTTN2 fields as well.
« Reply #73 on: October 19, 2013, 07:46:39 PM »
Good to know.
« Reply #74 on: October 19, 2013, 08:01:39 PM »
Is it correct, that flight data received by V5 Software is not used to feed RB24 Website?
