Your experience upgrading to 5.00.044
Started by Kenny, October 19, 2013, 07:05:58 AM
Mark Coles
what does it mean that the database has been encrypted and what is the purpose/advantage, tried to run some script and it failed because db is encrypted
thanks,
Mark
daily or weekly updates for your database
www.dbpop.co.uk
It is encrypted to ensure that it cannot be used outside the application
Quote from: AlanNo incorrect Ingo,
Well, then there seems to be a problem with my V5 on the desktop PC. Sharing is on, but no flights of this box is shown on RB24. Although I send my 24/7 PC into its weekly reboot. Ususally the flights are shared 60/40 (40 from 24/7 if the "big" one is on) if both machines are running. And if the 24/7 is going down for a weekly reboot 100% of shared flights are provided by desktop PC.
Hi Ingo,
If flights are shared with the network they should go to RB24 as it uses the network data.  Have you created an account on RB24 and linked your box?
Both boxes were linked for several month. I've used the update function of V5 software. Username and password of previously V4.03 version were automatically used to logon the ANRB V5 software after updating. Also the open and auto connect/logon function of the desktop link has worked flawlessly. Maybe its a firewall problem. I'll look what happens, if switch it off for a few minutes.
I would check the RB24 accounts settings as well.
RB24 settings already checke and re-entered to be shure. No effect. Switching off firewall: no effect. Reboot system and Software: No effect. Will wait to swicht to V5 on 24/7 machine until V5 -> RB24 connection is working for me. Deeper/further testing is difficult as I'm not at home and using remote acces to the RB computers.
The interesting thing is, that the V5 user id is the one with the expired network account. As the autopopulate/route update function is working, the box seems to be identified as a valid sharer by the AN servers. But for some reason the retrieved data isn't used for RB24 website and maybe the RB network. Maybe time will tell.
Good night and goodbye for today!
BlinkNFG
Thanks to everyone for their hard work on the update.  I have downloaded and installed V5 fine.  A significant improvement.
I do though continue to have a bug (I also had this in the previous version).  I thought (perhaps mistakenly) that this would be solved by the "The Spurious Position Bug" being fixed.  The issue I have is with landing aircraft.  At Stansted and Luton (my nearest airports) I can track these to a relatively low altitude (around 2,500 feet) before they time out.  However occasionally (maybe every 5-6 aircraft) after the aircraft has time out it is re-detected around 30 seconds later for 1-2 seconds but this time with an erroneous altitude (can be up to 36,000 feet).  As a result the end altitude for that flight in my log is shown as incorrect.
Jon
Thanks Jon,
I will pass on your report to the developer for further action.
With V4.03 I have this problem several times a day, too. To few landings in EDDV until now to tell if I still have it with V5.
mikek
I still have the following problem (that also existed on V4.03). On my Vista(...) computer, RB crashes whenever I return to from the screensaver or lock screen. It only occurs after I have installed MS Office 2010. As soon as I unstall Office, the crash does not occur. I am running as an administor. The following details come up:
Problem signature:
  Problem Event Name:   APPCRASH
  Application Name:   ANRB.exe
  Application Version:   1.0.0.1253
  Application Timestamp:   2a425e19
  Fault Module Name:   StackHash_3369
  Fault Module Version:   6.0.6002.18881
  Fault Module Timestamp:   51da3e27
  Exception Code:   c0000374
  Exception Offset:   000b06fc
  OS Version:   6.0.6002.2.2.0.768.3
  Locale ID:   5129
  Additional Information 1:   3369
  Additional Information 2:   6673edbfde6d717a58fc95c595104f9b
  Additional Information 3:   74e5
  Additional Information 4:   5e586a554cbda959b7ff88ccb1322b0d
I also operate RB sometimes on my laptop (Windows 8 64bit) with Office 2010 installed and this does not occur.
Mike
Aerotower
After update I have lost some of the planes in MyLog, like registration, Company name, etc...
And now my report see like this,
Report generated by AirNav RadarBox - 5.00.044
* 4841D8  TRA6608  LPFR-EHEH                                             2013/10/19 20:00:33
* 4841DB  TRA6203  EHEH-LPPT                                             2013/10/19 19:59:34
* 4841DB  TRA5956  LPPT-EHAM                                             2013/10/19 21:16:39
* 4844B1  P4BFL                                                          2013/10/19 17:55:32
* 484EE5  TRA503                                                         2013/10/19 17:06:43
* 484EE5  TRA504   LEMH-EHAM                                             2013/10/19 21:55:07
* 485009  TRA5951  EHAM-LPPT                                             2013/10/19 00:00:00
* 485009  TRA5952  LPPT-EHAM                                             2013/10/19 00:01:55
* 485009  TRA533   EHAM-GCTS                                             2013/10/19 15:47:08
* 485009  TRA534                                                         2013/10/19 20:04:52
* 491165  NJE947W                                                        2013/10/19 16:31:07
* 4951B7  TAP839   LIRF-LPPT                                             2013/10/19 15:34:21
* 4951B7  TAP438   LPPT-LFPO                                             2013/10/19 18:03:19
* 4951B7  TAP449   LFPO-LPPT                                             2013/10/19 22:40:39
* 4951C7  TAP576C  LPPT-EDDF                                             2013/10/19 15:50:28
* 4951C7  TAP579   EDDF-LPPT                                             2013/10/19 21:56:19
* 4951C9  TAP759   EKCH-LPPT                                             2013/10/19 10:51:59
* 4951C9  TAP441   LFPO-LPPT                                             2013/10/19 17:25:00
* 4951C9  TAP358A  LPPT-EGLL                                             2013/10/19 19:08:17
* 4951CB  TAP921   LSZH-LPPT                                             2013/10/19 13:01:35
* 4951CB  TAP436   LPPT-LFPO                                             2013/10/19 15:02:54
* 4951CB  TAP431   LFPO-LPPT                                             2013/10/19 19:32:11
* 4951CB  TAP1048  LPPT-LEBL                                             2013/10/19 21:06:17
* 4951CC  TAP757W  EKCH-LPPT                                             2013/10/19 17:47:36
* 4951CC  TAP448B  LPPT-LFPO                                             2013/10/19 19:36:44
* 4951D0  TAP1977  LPPR-LPPT                                             2013/10/19 19:25:04
* 4951D0  TAP838J  LPPT-LIRF                                             2013/10/19 20:53:04
* 4951D2  TAP537M  LPPT-EDDB                                             2013/10/19 17:18:09
* 4951D2  TAP566   LPPT-EDDH                                             2013/10/19 18:41:04
* 4951D3  TAP798   LPPT-EFHK                                             2013/10/19 11:44:30
* 4951D3  TAP793   EFHK-LPPT                                             2013/10/19 21:18:17
* 4951D3  TAP796   LPPT-EFHK                                             2013/10/19 22:54:50
* 4951D6  TAP1978  LPPT-LPPR                                             2013/10/19 16:55:05
* 495201  TAP478   LPPT-LFLL                                             2013/10/19 14:58:44
* 495203  TAP1981  LPPR-LPPT                                             2013/10/19 16:14:55
* 495203        2013/10/19 21:20:27
* 495204  TAP433   LFPO-LPPT                                             2013/10/19 14:38:49
* 495204  TAP496   LPPT-LFBO                                             2013/10/19 16:25:26
* 495204  TAP493   LFBO-LPPT                                             2013/10/19 19:43:22
* 495204  TAP2690                                                        2013/10/19 21:45:08
* 495206  TAP1956  LPPT-LPPR                                             2013/10/19 11:03:12
* 495206  TAP1018  LPPT-LEMD                                             2013/10/19 19:16:59
* 495206  TAP1019  LEMD-LPPT                                             2013/10/19 21:26:24
* 495207  TAP1097  LEVC-LPPT                                             2013/10/19 11:44:28
* 495207  TAP1042  LPPT-LEBL                                             2013/10/19 13:19:37
* 495207  TAP1043  LEBL-LPPT                                             2013/10/19 16:59:08
* 495207  TAP1046  LPPT-LEBL                                             2013/10/19 18:44:08
* 495207  TAP1047  LEBL-LPPT                                             2013/10/19 22:08:18
* 495209  TAP409   LFML-LPPT                                             2013/10/19 13:01:07
* 495209  TAP484   LPPT-LFMN                                             2013/10/19 14:39:07
* 495209  TAP487   LFMN-LPPT                                             2013/10/19 19:26:42
* 495209  TAP1980  LPPT-LPPR                                             2013/10/19 21:01:36
* 49520B  TAP464   LPPT-LFBD                                             2013/10/19 15:45:07
* 49520B  TAP469   LFBD-LPPT                                             2013/10/19 19:16:13
* 49520B  TAP1090  LPPT-LEVC                                             2013/10/19 21:14:58
* 49520C        2013/10/19 10:51:02
* 49520C  TAP1015  LEMD-LPPT                                             2013/10/19 14:35:30
* 49520C  TAP249   DAAG-LPPT                                             2013/10/19 20:25:02
* 49520E  TAP1041  LEBL-LPPT                                             2013/10/19 13:01:08
* 49520E  TAP237   GMMN-LPPT                                             2013/10/19 18:00:37
* 49520E  TAP486   LPPT-LFMN                                             2013/10/19 20:50:10
* 495224  TAP787B  ESSA-LPPT                                             2013/10/19 18:24:39
* 495224  TAP552   LPPT-EDDM                                             2013/10/19 20:18:40
* 495282  TAP561   EDDH-LPPT                                             2013/10/19 14:40:08
* 495282  TAP1016  LPPT-LEMD                                             2013/10/19 16:20:19
* 495282  TAP1021  LEMD-LPPT                                             2013/10/19 18:40:21
* 495282  TAP942   LPPT-LSGG                                             2013/10/19 20:24:23
* 495283  TAP329   EGCC-LPPT                                             2013/10/19 14:35:01
* 495283  TAP356   LPPT-EGLL                                             2013/10/19 16:08:51
* 495283  TAP377   EGLL-LPPT                                             2013/10/19 21:30:30
* 495285  TAP1908  LPFR-LPPT                                             2013/10/19 11:44:28
* 495285  TAP344L  LPPT-EGKK                                             2013/10/19 13:01:08
* 495285  TAP341   EGKK-LPPT                                             2013/10/19 18:15:09
* 495285  TAP668   LPPT-EHAM                                             2013/10/19 20:10:43
* 495286  TAP573J  EDDF-LPPT                                             2013/10/19 15:32:30
* 495286  TAP364   LPPT-EGLL                                             2013/10/19 17:14:04
* 495286  TAP367A  EGLL-LPAR                                             2013/10/19 22:06:12
* 495287  TAP1828  LPLA-LPPT                                             2013/10/19 00:00:00
* 495287        2013/10/19 10:50:57
* 495287  TAP359G  EGLL-LPPT                                             2013/10/19 15:51:23
* 495287  TAP9316                                                        2013/10/19 19:43:15
* 495288  TAP714   LPPT-LHBP                                             2013/10/19 15:53:38
* 495288  TAP713   LHBP-LPPT                                             2013/10/19 22:41:20
* 49528A  TAP761   ENGM-LPPT                                             2013/10/19 17:20:41
* 49528A  TAP928   LPPT-LSZH                                             2013/10/19 19:28:35
* 49528B  TAP947   LSGG-LPPT                                             2013/10/19 13:01:08
* 49528B  TAP804   LPPT-LIMC                                             2013/10/19 14:34:23
* 49528B  TAP809   LIMC-LPPT                                             2013/10/19 19:38:19
* 49528B  TAP1022  LPPT-LEMD                                             2013/10/19 21:18:30
* 49528D  TAP373   EGLL-LPPT                                             2013/10/19 14:34:26
* 49528D  TAP612   LPPT-EBBR                                             2013/10/19 17:55:23
* 49528E  TAP722   LPPT-LROP                                             2013/10/19 00:00:00
* 49528E  TAP801   LIMC-LPPT                                             2013/10/19 14:53:02
* 49528E  TAP614   LPPT-EBBR                                             2013/10/19 16:54:47
* 49528E  TAP619   EBBR-LPPT                                             2013/10/19 22:02:24
* 4B161E  EDW298   LSZH-LPFR                                             2013/10/19 17:50:21
* 4B161E  EDW299   LPFR-LSZH                                             2013/10/19 19:42:19
* 4CA13D  EIN494   EIDW-LPFR                                             2013/10/19 16:22:08
* 4CA13D  EIN495   LPFR-EIDW                                             2013/10/19 19:04:18
* 4CA15C  EIN778   EIDW-GCRR                                             2013/10/19 16:52:30
* 4CA15C  EIN77M   GCRR-EIDW                                             2013/10/19 21:40:45
* 4CA246  RYR5278  LEMD-GCXO                                             2013/10/19 17:00:20
* 4CA246  RYR5279  GCXO-LEMD                                             2013/10/19 21:53:41
* 4CA294  EIN484   EIDW-LPPT                                             2013/10/19 14:38:19
* 4CA294  EIN485   LPPT-EIDW                                             2013/10/19 17:00:29
* 4CA2C9  EIN770   EIDW-GCFV                                             2013/10/19 18:01:26
* 4CA2C9  EIN771   GCFV-EIDW                                             2013/10/19 22:47:01
* 4CA2D4  RYR53W   EIDW-GCLP                                             2013/10/19 16:26:50
* 4CA2D4  RYR12GM  GCLP-EIDW                                             2013/10/19 21:25:38
* 4CA640  EIN883   LEMG-EICK                                             2013/10/19 11:20:38
* 4CA640  EIN876   EICK-GCRR                                             2013/10/19 16:10:51
* 4CA640  EIN877   GCRR-EICK                                             2013/10/19 20:45:15
* 4CA73A  RYR62MU  EDLV-GCRR                                             2013/10/19 15:50:28
* 4CA73A  RYR6MQ   GCRR-EDLV                                             2013/10/19 20:40:31
* 4CA760  RYR2573  LEMG-LEST                                             2013/10/19 19:40:05
* 4CA762  RYR1KW   EGSS-LPFR                                             2013/10/19 19:18:13
* 4CA762  RYR26VA  LPFR-EGSS                                             2013/10/19 21:17:02
* 4CA7B3  RYR31GD  EGGD-GCLP                                             2013/10/19 13:04:06
* 4CA7B3  RYR2011  LEMD-GCLP                                             2013/10/19 18:32:38
* 4CA891  RYR6312  EBCI-LPFR                                             2013/10/19 12:00:52
* 4CA891  RYR5487  LPFR-LPPR                                             2013/10/19 13:39:18
* 4CA891  RYR5486  LPPR-LPFR                                             2013/10/19 14:59:22
* 4CA891  RYR36GQ  LPFR-EIDW                                             2013/10/19 16:57:37
* 4CA891  RYR36GQ  LPFR-EIDW                                             2013/10/19 21:43:55
* 4CA891  RYR97LA  EIDW-LPFR                                             2013/10/19 21:50:18
* 4CA894  RYR4XZ   EGSS-GCLP                                             2013/10/19 16:26:50
* 4CA894  RYR8TW   GCLP-EGSS                                             2013/10/19 21:28:53
* 4CA8E6  RYR6XH   EGNM-LPFR                                             2013/10/19 14:44:09
* 4CA8E6  RYR86EC  LPFR-EGGD                                             2013/10/19 17:20:24
* 4CA8E6  RYR39YC  EGGD-LPFR                                             2013/10/19 21:38:36
* 4CA8E7  RYR7442  ESKN-LPFR                                             2013/10/19 16:03:23
* 4CA8E7  RYR9LQ   LPFR-EGNX                                             2013/10/19 17:47:47
* 4CA8E7  RYR7BK   EGNX-LPFR                                             2013/10/19 22:51:55
* 4CA8E9  RYR63CH  EGHH-GCLP                                             2013/10/19 13:30:49
* 4CA8E9  RYR7003  GCLP-LEST                                             2013/10/19 18:31:16
* 4CA8E9  RYR7004  LEST-GCLP                                             2013/10/19 20:22:20
* 4CA8EB  RYR51XA  EGGP-LPFR                                             2013/10/19 14:34:23
* 4CA8EB  RYR4VT   LPFR-EGBB                                             2013/10/19 16:37:57
* 4CA8EB  RYR4LJ   EGBB-LPFR                                             2013/10/19 21:30:42
* 4CA90F  RYR8PT   LPFR-EGSS                                             2013/10/19 17:43:24
* 4CA90F  RYR1TA   EGSS-LPFR                                             2013/10/19 22:42:04
* 4CA911        2013/10/19 20:37:15
* 4CA935  EIN774   EIDW-GMAD                                             2013/10/19 18:51:10
* 4CA935  EIN775   GMAD-EIDW                                             2013/10/19 22:55:53
* 4CA947  EIN498   EIDW-LPFR                                             2013/10/19 18:35:00
* 4CA947  EIN49T   UUEE-KJFK                                             2013/10/19 20:37:45
* 4CA96B  RYR72CX  EIKN-LPFR                                             2013/10/19 14:00:41
* 4CA96B  RYR5KM   LPFR-EGCC                                             2013/10/19 16:05:11
* 4CA96B  RYR6AW   EGCC-LPFR                                             2013/10/19 21:23:13
* 4CA96C  RYR97JQ  EGGP-GCRR                                             2013/10/19 16:59:50
* 4CA96C  RYR6KB   GCRR-EGGP                                             2013/10/19 21:20:50
* 4CA96E  RYR1991  GCTS-LEXJ                                             2013/10/19 19:10:30
* 4CA96E  RYR2904  LEXJ-GCTS                                             2013/10/19 21:41:21
* 4CA9CC  RYR6DU   EIDW-GCRR                                             2013/10/19 16:10:20
* 4CA9CC  RYR7T    GCRR-EIDW                                             2013/10/19 21:00:31
* 4CA9CD  RYR5712  EDFH-LPFR                                             2013/10/19 15:10:35
* 4CA9CD  RYR6165  LPFR-EDLV                                             2013/10/19 17:35:14
* 4CA9CD  RYR6164  EDLV-LPFR                                             2013/10/19 23:12:31
* 4CA9ED  RYR7XY   EGGP-GCFV                                             2013/10/19 17:11:26
* 4CA9ED  RYR9AH   GCFV-EGGP                                             2013/10/19 21:44:44
* 4CAA57  RYR9VF   GCTS-EGPH                                             2013/10/19 21:11:35
* 4CAA61  RYR7469  EHBK-LPFR                                             2013/10/19 13:01:08
* 4CAA61  RYR7481  LPFR-EDJA                                             2013/10/19 14:53:12
* 4CAA61  RYR7482  EDJA-LPFR                                             2013/10/19 20:15:37
* 4D00F8        2013/10/19 17:46:45
* 4D209B        2013/10/19 18:02:26
* 502C8F  TCX17VE                                                        2013/10/19 14:59:46
* ACB177        2013/10/19 16:24:20
* AD8EDE  AVA010                                                         2013/10/19 13:04:06
* AD8EDE  AVA017   LEMD-SKRG                                             2013/10/19 16:10:36
* E02354  ARG1132  SAEZ-LEMD                                             2013/10/19 17:01:04
* E02354  ARG1132  SAEZ-LEMD                                             2013/10/19 22:31:51
* E02354  ARG1133  LEMD-SAEZ                                             2013/10/19 22:33:07
* E80420  LPE2706  SPIM-LEMD                                             2013/10/19 16:34:37
* 896173  UAE191   OMDB-LPPT       A6-EWA     B77L  Emirates             2013/10/19 14:34:41
* 896173                           A6-EWA     B77L  Emirates             2013/10/19 18:21:19
* E8040F  LAN704   SCEL-LEMD-EDDF  CC-BBB     B788  LAN Airlines         2013/10/19 11:22:31
* E80276  LAN9901                  CC-BFS     A320  LAN Airlines         2013/10/19 11:09:27
New Aircraft entries have the symbol *
--- End of Report ---
I have select the autopopulate in preferences.
But I'm so disapointed.......
