Your experience upgrading to 5.00.044
Started by Kenny, October 19, 2013, 07:05:58 AM
Kenny
The  VTBD label on 2D map is now corrected, however, still no VTBS label (see attach).
ANRB 3km north of VTBD
vonsmalhausen
uninstalled version 5, and reinstalled version 4 : network back on again and no more strange ID's
applied the update again....... network gone again
this is defenatly a version 5 problem
I dont have anywhere near 36471 photos in my folder but it still takes a while for all my photos to open.  Even thought it showed not responding it still opened up when I just tried it, even if it took some time.  37,000 photos is a lot of data to open up and will take a while to open them all up
neroon79
Is it possible, that your firewall -if you are using one- is having a problem with version 5?
Own problem:
Log and altert sending by using own mail account ist not working. Mail/alert via Server is working. Mail Account configuration in ANRB is identical to mail program. Firewall comsettings of ANRB and Mail program altered to identical settings. I gettting still the sent failed notification from ANRB software.
11.75nm ESE of EDDV
HW:
Cable: 25m of ECOFLEX 15+
NB: Asus P53E 24/7 op.
PC: 28"4K + 24" Monitor
AirSpy mini @RPi3
Kenny,
That part has not been sorted yet.
EK01
Alan,
I have the exact same problem as CoastGuardJon with the same long screed of fault messages. I also have to use the Task Manager to close the thing down. Beginning now to feel a bit like vonsmalhausen. I can't even get the original version back on.
Giving up and closing down. What a waste of time !
Ingo,
Even although your getting the sent failed notification, did the mail get sent.
neroon79
QuoteI dont have anywhere near 36471 photos in my folder but it still takes a while for all my photos to open.  Even thought it showed not responding it still opened up when I just tried it, even if it took some time.  37,000 photos is a lot of data to open up and will take a while to open them all up
This is a known fact and I gave the V5 twice the time V4 had needed to open the pictures. Maybe I should rename the folder and start with a blanc one. Last time I flushed the folder was about three years ago, so many airframe pictures will be already outdated by now too.
I have about 27000 (22000 in the past 280 days on the 24/7 box) airframes in my MyLog. Two pictures for each airframe...
Ingo
11.75nm ESE of EDDV
HW:
AirSpy mini @RPi3
neroon79
Mail haven't been sent. No rise in upload traffic, No mail received with destination address. Switched back to server mode and tried again. Rise in uplaod traffic and LOG/Data received, no "sent failed" notification.
Ingo
11.75nm ESE of EDDV
HW:
AirSpy mini @RPi3
neroon79
The naming of the donwloaded photo has changed withing V5:
is it still possible to insert individual ones in the old reg / reg,2 format?
Ingo
11.75nm ESE of EDDV
HW:
AirSpy mini @RPi3
Yes Ingo,  photo's can still be added manually as before.  However I believe you have to add the aircraft registration into the PTTN and PTTN2 fields as well.
neroon79
11.75nm ESE of EDDV
HW:
AirSpy mini @RPi3
neroon79
Is it correct, that flight data received by V5 Software is not used to feed RB24 Website?
Ingo
11.75nm ESE of EDDV
HW:
AirSpy mini @RPi3
