Author Topic: Cannot use the radarbox  (Read 30042 times)
aarbee
« on: April 19, 2008, 02:43:45 PM »
I have received the radarbox today.
I have installed the program, and connected it to the pc.
But I cannot use the program, as it is telling, that I need to use a userid and password???
If so, then be it, but, I think I need at least a place where I can register it.
Can you help me to the location of the registration form?
Greetings,
RobB
Re: Cannot use the radarbox
« Reply #1 on: April 19, 2008, 02:46:12 PM »
Greetings,
RobB
Look at the white label on the blue cardboard CD cover:
Username: PGANRB100***
Password: 1234**********
« Last Edit: April 19, 2008, 02:57:50 PM by Allocator »
Roadrunner
« Reply #2 on: April 19, 2008, 02:47:34 PM »
The installation disc/paperwork with the radarbox should have a code on it. If I remember correctly it was on the slip that was used to seal the disc.
Mike
aarbee
« Reply #3 on: April 19, 2008, 02:51:56 PM »
Ohoh, I am ashamed.
I flipped the front part to the back of that cd-holder, at the second I took it out of the box.
To eager to start.
Sorry, Should have looked more carefully I think.
I have planes in the sky. ;-)
I expected more, as it is crowded here.
Roadrunner
« Reply #4 on: April 19, 2008, 02:54:34 PM »
Welcome to the club. Just wait and see how long it is before it becomes addictive :-)
« Reply #5 on: April 19, 2008, 03:00:37 PM »
Ohoh, I am ashamed.
To eager to start.
aarbee,
welcome to the forum - I thought that maybe you had thrown away the packing in your excitement :-)
Experiment with the position of your antenna to ge the most traffic.  Ideally, it should have a clear view of the sky as it picks up the Mode S transmissions that are in "line of sight" - if you are in the basement, then you might have problems :-0
aarbee
« Reply #6 on: April 19, 2008, 03:40:51 PM »
I saw the firmware. 1.01.2
Advisable to upgrade?
aarbee
« Reply #7 on: April 19, 2008, 03:46:43 PM »
« Reply #8 on: April 19, 2008, 03:47:46 PM »
Just upgrade to 1.5 as shown on the support page. Pleas read the important notice first and as it says do NOT attempt the RadarBox 2007 (1.3) install.
« Reply #9 on: April 19, 2008, 03:48:00 PM »
NO - You have the latest firmware.
aarbee
« Reply #10 on: April 19, 2008, 03:52:25 PM »
I have placed the image of what I see on the software.
My flights is empty. I guess, that are the flights I should see.
I have un switched the "Get flights from RadarBox network".
Yet I sill see 24 flights on the network part.
Where do they come from?
« Reply #11 on: April 19, 2008, 03:57:27 PM »
aarbee, where is your antenna located?
I'd start by installing RadarBox 2008 (That's V1.5) then go from there.
RadarBox 2008 will install to a new directory, so there is no need to un-install the version you have.  V1.5 has a whole load of bug-fixes.
aarbee
« Reply #12 on: April 19, 2008, 03:58:03 PM »
Odd... Version 2008/1.5 sees 17 flights of me.
Direction of south-west. which is the direction of the window.
BTW, what happens if I place this on the attick?
I have a nas-server over there?
Can I look at the screen via the software, or only via rdp?
Thanks sofar, for your kind answers.
« Last Edit: April 19, 2008, 04:00:14 PM by aarbee »
« Reply #13 on: April 19, 2008, 03:59:45 PM »
aarbee, the antenna needs to "see" the aircraft.  If you have a wall in the way, you won't get any aircraft in that direction :-)
DVDW
  • RadarBox Beta Testers
« Reply #14 on: April 20, 2008, 05:48:55 AM »
Hey Arbee,
Your antenna needs a clear line of sight. For the best results an outside antenna is recommendable. Nice to meet someone who's located in Belgium just as me.
Dirk.
