Cannot use the radarbox
Started by aarbee, April 19, 2008, 02:43:45 PM
aarbee
I have received the radarbox today.
I have installed the program, and connected it to the pc.
But I cannot use the program, as it is telling, that I need to use a userid and password???
If so, then be it, but, I think I need at least a place where I can register it.
Can you help me to the location of the registration form?
Greetings,
RobB
#1
Quote from: aarbee on April 19, 2008, 02:43:45 PM
Greetings,
RobB
Look at the white label on the blue cardboard CD cover:
Username: PGANRB100***
Password: 1234**********
Roadrunner
The installation disc/paperwork with the radarbox should have a code on it. If I remember correctly it was on the slip that was used to seal the disc.
Mike
aarbee
Ohoh, I am ashamed.
I flipped the front part to the back of that cd-holder, at the second I took it out of the box.
To eager to start.
Sorry, Should have looked more carefully I think.
I have planes in the sky. ;-)
I expected more, as it is crowded here.
Roadrunner
Welcome to the club. Just wait and see how long it is before it becomes addictive :-)
Quote from: aarbee on April 19, 2008, 02:51:56 PM
Ohoh, I am ashamed.
To eager to start.
aarbee,
welcome to the forum - I thought that maybe you had thrown away the packing in your excitement :-)
Experiment with the position of your antenna to ge the most traffic.  Ideally, it should have a clear view of the sky as it picks up the Mode S transmissions that are in "line of sight" - if you are in the basement, then you might have problems :-0
aarbee
I saw the firmware. 1.01.2
Advisable to upgrade?
Just upgrade to 1.5 as shown on the support page. Pleas read the important notice first and as it says do NOT attempt the RadarBox 2007 (1.3) install.
Quote from: aarbee on April 19, 2008, 03:40:51 PM
NO - You have the latest firmware.
aarbee
I have placed the image of what I see on the software.
My flights is empty. I guess, that are the flights I should see.
I have un switched the "Get flights from RadarBox network".
Yet I sill see 24 flights on the network part.
Where do they come from?
Quote from: aarbee on April 19, 2008, 03:52:25 PM
aarbee, where is your antenna located?
I'd start by installing RadarBox 2008 (That's V1.5) then go from there.
RadarBox 2008 will install to a new directory, so there is no need to un-install the version you have.  V1.5 has a whole load of bug-fixes.
aarbee
#12
Odd... Version 2008/1.5 sees 17 flights of me.
Direction of south-west. which is the direction of the window.
BTW, what happens if I place this on the attick?
I have a nas-server over there?
Can I look at the screen via the software, or only via rdp?
Thanks sofar, for your kind answers.
Quote from: aarbee on April 19, 2008, 03:58:03 PM
aarbee, the antenna needs to "see" the aircraft.  If you have a wall in the way, you won't get any aircraft in that direction :-)
DVDW
Hey Arbee,
Your antenna needs a clear line of sight. For the best results an outside antenna is recommendable. Nice to meet someone who's located in Belgium just as me.
Dirk.
