Started by orkney, May 31, 2014, 11:20:28 AM
flygfantast
ABAFC0 N852L, Cessna 525 CJ1+, c/n 525-0625, Pilot International Inc (ex D-IEPR)
Niklas
Cable: Ecoflex-10 (10m+1m)
CYYZGUY
Hi Alan, a flight lacking some information here.
Mode-S A0998A
Flight ID TWY7
No Registration or Aircraft Type populatng.  Coming up as Solairus Aviation
regards,
Jason
40" LED Monitor
40" LED Monitor
Hi Ingo,
I cant find any details on 4243CE  VQBZB either and VQ-BZB is in the d/b as you state.
Hi Jason,
A0998A decodes to N138GL and the FAA list shows that G550 N476GA has requested a number change to N138GL so I presume the change has taken place.  Still showing as registered to the manufacturer.
Morning, from Monday:
3CC23C PWF30-PWF32 D-CAWA D328-110 PRIVATE WINGS FLUGCHARTER CN 3119
3D97B8 DGDSA nothing found
3DAB12 DGLAO nothing found
3E2DE DIIPA Piper PA-34-220T Seneca V (seems to be for sale)
Thanks again Ingo, I cant find anything on those two either yet.
Michel
Alan,
TRA806R LGTS-EHAM
TRA580P EHAM-LGTS
TRA357Q EHAM-LPFR
TRA356P LPFR-EHAM
TRA951Z EHAM-LPPT
TRA753R EHAM-GMMX
TRA611R EHAM-LEMG
TRA7W EHAM-LEMG
TRA2H LEMG-EHAM
TRA118J LEMG-EHAM
TRA93C EHAM-GCLP
Michel.
#1360
Thanks for that falcon_nl.  Anyone any ideas on the type?
Afternoon, MIL from Yesterday:
* 3E87C0  GAF177                                                         2014/10/13 06:31:25
* 3E9486  ATTACK                                                         2014/10/13 08:22:47
   3E9FE9  GAF132                                                         2014/10/13 08:26:49
   3EA75D        2014/10/13 08:04:42
* 3EB284        2014/10/13 11:56:01
* 3F77E2  GAF696                                                         2014/10/13 10:32:46
   3F8AD6  HG01B                                                          2014/10/13 06:19:17
   3F956E        2014/10/13 12:12:19
* 3FACD9  GAFR09                                                         2014/10/13 08:18:38
Received 2014/10/13 11:13:34: ABAFC0  N852L (already posted by Niklas (flygfantast))
#1362
Thanks again Ingo.  N852L is in the d/b already.
M
Quote from: Runway 31Thanks for that falcon_nl.  Anyone any ideas on the type?
Partenavia P68 (Lips Flugdienst). Probably ex N46810.
http://www.lips-flugdienst.de/Partenavia-P-68-C-TC.55.0.html
#1364
Many thanks M, thought it was but want sure, would make it c/n 334-29-TC
