Started by orkney, May 31, 2014, 11:20:28 AM
Hi Mike,
Nothing on 7500F2 and A829B2 decodes to N625KA which makes it c/n FL-825.
thanks again
Michel
Alan,
CFG2FA EDDH-GCFV iso GCTS-EDDP
Michel.
Afternoon Alan,
Just come over with full ADSB is an A330-243 c/n 1186 of UAE AF registered '1301'. Unfortunately, the accompanying photos are certainly not of an A330 but appear to be of an unserviceable Mig also registered '1301'. Can you do the necessary at your end please.
Will do Ian, I never got a photo, can you delete the Mig from your photo folder
Somebody asked about N374CH the other day and the FAA website shows it as cancelled from the register.  Guess what it arrived at Prestwick this afternoon so added back into the d/b.
A442E1 N374CH Beech B300 King Air 350 c/n FL-449 US - Navy
Evening, the unknowns from Monday:
   3443D7        2014/06/02 16:54:57
* 3C4944        2014/06/02 07:08:07
   3D2D3C        2014/06/02 13:23:49
* 3E96F4        2014/06/02 05:00:34
   3E9FDC  TIGER                                                          2014/06/02 08:16:42
   3E9FDC  TIGER                                                          2014/06/02 10:00:05
* 3EAF7F  GAF054                                                         2014/06/02 09:03:59
* 3EE2D1  D0570                                                          2014/06/02 12:18:46
* 3EE2D1  D0570                                                          2014/06/02 13:23:31
* 3EE2D1        2014/06/02 14:10:43
   3F6E76        2014/06/02 08:04:36
* 3F8930        2014/06/02 13:35:03
* 40086C        2014/06/02 11:54:41
* 471E5D        2014/06/02 19:36:33
   484157        2014/06/02 12:38:22
   484196        2014/06/02 05:00:30
* 49D345        2014/06/02 12:54:09
   4B1609        2014/06/02 08:16:55
   4B169F        2014/06/02 18:41:11
* 740720        2014/06/02 12:58:45
* 8678CE        2014/06/02 19:16:44
   EA0000        2014/06/02 08:21:24
Regards Ingo
Evening Ingo,
3443D7 unknown to me
3C4944 decodes to D-ABJD unknown to me
3D2D3C decodes to D-EPJO unknown to me
3EE2D1,D-0570,4798,Rolladen-Schneider LS-4A
40086C not current
471E5D unknown to me
484157 not allocated
484196 not allocated
49D345 not allocated
4B1609 not allocated
4B169F not current
740720 unknown to me
8678CE decodes to JA715Q unknown to me
EA0000 unknown miscode
Evening Alan,
Two for you :
VLG7748 : LEAL-ULLI
IBE3234 : LEMD-LIRF
Hi Ian,
Good morning to you on this lovely morning and thanks again.
Good Afternoon, the unknowns from Tuesday:
* 3C665F        2014/06/03 09:01:25
   3D38EF        2014/06/03 08:54:39
   3D38EF        2014/06/03 13:04:31
* 3EB728  TA62                                                           2014/06/03 07:05:32
* 3EB728        2014/06/03 10:51:28
* 3EB728  TA24                                                           2014/06/03 12:24:53
* 3F4343  PANTER                                                         2014/06/03 08:08:13
* 3F43CE  GAF204   BIKF-CYQX                                             2014/06/03 06:24:28
   3F5621  GAF320                                                         2014/06/03 06:18:08
   3F5621  GAF320                                                         2014/06/03 08:52:08
* 3F6885  MONSTR1                                                        2014/06/03 08:05:56
* 3F6885  MONSTR1                                                        2014/06/03 09:18:05
* 3F6885  DRAGON1                                                        2014/06/03 12:55:51
* 3F6885  DRAGON                                                         2014/06/03 14:09:11
* 3F9123  DRAGON2                                                        2014/06/03 13:52:41
   3FAE3D        2014/06/03 08:24:15
   3FAE3D        2014/06/03 09:20:26
   3FEFE9  DMDDO                                                          2014/06/03 09:43:42
   3FF182  DMEAJ                                                          2014/06/03 10:29:52
* 4400BA        2014/06/03 06:32:18
   473400        2014/06/03 09:57:47
* 4784A6        2014/06/03 20:10:51
* 4841AC        2014/06/03 21:48:04
   730000        2014/06/03 15:16:28
   730000  GNY4904                                                        2014/06/03 19:09:02  miscoded MIL would be my first guess.
* 78492E        2014/06/03 07:23:32
   EA0000        2014/06/03 02:00:06
* EB00F3        2014/06/03 01:59:54
Regards Ingo
Evening Ingo,
3C665F doesn't decode
3D38EF decodes to D-ETUT unknown to me
3FEFE9 D-MDDO unknown to me
3FF182 D-MEAJ AutoGyro Cavalon c/n V00042
4400BA not current
473400 unknown to me
4784A6 decodes to LN-ODU w/o
4841AC last used by PJ-HRM, not current
730000 with a GNY flight ID I presume you  are correct
78492E unknown to me
EA0000 miscode unknown to me
EB00F3 miscode unknown to me
flygfantast
SE-LKY, 4AB179, is operated by Bromma Air Maintenance for LFV (used for flight inspections, http://www.bam.aero/en/flight-inspection)
Niklas
Cable: Ecoflex-10 (10m+1m)
