Started by orkney, May 31, 2014, 11:20:28 AM
Evening Niklas, amended thanks
Michel
Alan,
NAX5408 LEMD-ESSA
Michel.
diddyboy
Hi Alan
2 more from Home.
* 383BBA        2014/06/04 11:17:28
* 4CA2DD        2014/06/04 19:56:09
Xon
48CA69 SP-TUK TAMP c/n 1635
48CA6D SP-TUN TAMP c/n 1089
48B22E SP-MSO M7 c/n 25108C
Hi Neil,
383BBA decodes to F-WWRF SOCATA Test Registration
4CA2DD  decodes to EI-DMO long broken up, probable corrupt packet
#51
Hi Xon,
48CA69 decodes to SP-TUJ which doesn't exist, SP-TUK should use 48CA6A and is operating in the Rzeszow area at this time with SP-TUM which is correctly coded 48CA6C.  SP-TUK is either incorrectly coded or it has been tied up incorrectly
48CA62,SP-TUC,3449414,Piper PA-34-220T Seneca V,Politechnika Rzeszowska,,PA34
48CA63,SP-TUD,3449412,Piper PA-34-220T Seneca V,Pilitechnika Rzeszowska,,PA34
48CA64,SP-TUE,3449428,Piper PA-34-220T Seneca V,Pilitechnika Rzeszowska,,PA34
48CA6A,SP-TUK,1635,SOCATA TB9 Tampico,OKL - Aviation Training Centre of Rzeszow Technica,,TAMP
48CA6B,SP-TUL,1722,SOCATA TB9 Tampico,OKL - Aviation Training Centre of Rzeszow Technica,,TAMP
48CA6C,SP-TUM,1787,SOCATA TB9 Tampico,OKL - Aviation Training Centre of Rzeszow Technica,,TAMP
48CA6D,SP-TUN,1089,SOCATA TB9 Tampico,OKL - Aviation Training Centre of Rzeszow Technica,,TAMP
48CA6E,SP-TUO,882,SOCATA TB9 Tampico,OKL - Aviation Training Centre of Rzeszow Technica,,TAMP
X
It was me who asked about N374CH beech US Navy
86D251 JA813P A320 Peach Aviation was into DWC last night at 0045 but did not populate
X
Michel
Alan,
CND311 EHAM-LGKR iso EHAM-GBYD
TRA825 EHAM-LTFG
TRA1857 EHAM-LGIR​
TFL253 EHAM-LGKO iso EHAM-LTAI
Michel.
#54
Hi X,
I added it in when I came back from the pub last night so should be in todays Navdata update.
The B350 was all white with only the registration marks on it.  It was with another one N316W and they both left for Keflavik after a night stop.
shouriken
4A0833 - YR-BAS - B734 - Boeing 737-430 - 27007/2367 - Blue Air (ex. HS-GTC)
Will fly BMS123 LROP-EBBR (EOBT 2014-06-05 12:25)
Liviu
A.net JetPhotos.Net
RadarBox
Good Afternoon, the unknowns from Wednesday:
* 00AC0D        2014/06/04 08:14:47
* 07B59C        2014/06/04 20:28:03
* 3C4589        2014/06/04 22:21:06
   3C48CC        2014/06/04 16:52:15
* 3C48F5        2014/06/04 08:46:43
* 3C6427        2014/06/04 10:44:23
   3C658A        2014/06/04 06:34:44
   3D0972        2014/06/04 05:10:20
   3D0972        2014/06/04 14:37:14
* 3E3714  DIMBC                                                          2014/06/04 08:14:30
* 3E3714  DIMBC                                                          2014/06/04 11:07:01
* 3E3714        2014/06/04 13:25:48
* 3E3714        2014/06/04 16:04:14
* 3E83D4  GAF074                                                         2014/06/04 06:28:37
* 3EBEDC  GAF674                                                         2014/06/04 14:50:13
* 3F45BC        2014/06/04 10:00:52
* 3F4899  APEX2                                                          2014/06/04 13:34:06
* 3F4FBB  BOMBER                                                         2014/06/04 08:27:46
* 3F4FBB        2014/06/04 09:21:40
* 3F4FBB  ATTACK                                                         2014/06/04 13:19:08
* 3F6610  SHOCK1                                                         2014/06/04 06:58:03
* 3F7FE2  GAF807                                                         2014/06/04 08:49:14
* 3FAC0D  TIGER                                                          2014/06/04 08:05:38
* 3FAC0D        2014/06/04 09:39:43
* 3FAE25        2014/06/04 07:33:59
* 4AC8F2        2014/06/04 05:55:37
   4CA642        2014/06/04 10:47:01
Regards Ingo
Evening Ingo,
00AC0D decodes to ZS-QRC unknown to me
07B59C unknown miscode
3C4589  decodes to D-AALI unknown to me
3C48CC decodes to D-ABFL unknown to me
3C48F5 decodes to D-ABGU unknown to me
3C6427 decodes to D-AIAG unknown to me
3C658A decodes to D-AILJ unknown to me
3D0972 decodes to D-EBVE uknown to me
3E3714 D-IMBC unknown to me
4AC8F2 doesn't decode
4CA642 not current
