Started by orkney, May 31, 2014, 11:20:28 AM
Morning, unknowns from Saturday:
* 2375D7        2014/07/05 09:04:00
* 3950DA        2014/07/05 11:44:39
   3C4893  BER272K  LEMD-EDDT         bad packet
* 3CCD39  IFA100   EGKB-EDDN                                             2014/07/05 14:48:31
   3D46D8        2014/07/05 12:14:47
   3D46D8        2014/07/05 14:41:19
   4068F2        2014/07/05 21:25:17
* 43CB01        2014/07/05 14:00:19
* 459457        2014/07/05 08:08:49
   45AC36  SAS1685  EKCH-LIMC     bad packet
   471F5E        2014/07/05 05:31:15
   48418E        2014/07/05 06:36:35
* 485073        2014/07/05 08:11:51
   4B1692        2014/07/05 16:31:55
   4BA8C1        2014/07/05 14:31:54
* 50004D        2014/07/05 13:40:23
* 587592        2014/07/05 09:04:02
Hi Ingo,
2375D7 miscode unknown to me
3950DA  doesn't decode
3CCD39,D-CFAF,60-107,Learjet 60,FAI Rent-A-Jet
3D46D8 D-EZBS unknown to me
4068F2 not current
43CB01 unknown to me
459457,OY-EBW,743,Aerospatiale ATR 72-212A
471F5E unknown to me
48418E not current
485073,PH-1AF,3733,HiSystems MK L4
4B1692 not current
4BA8C1 unknown to me
50004D decodes to T7-AHB, no further info
587592  miscode, no country allocation
CYYZGUY
#409
Hi Alan, in case you missed post #401 :)
Also, ACA7192  No Route  another EuroAtlantic..but seems to have a set route..
http://flightaware.com/live/flight/ACA7192
Thank you! :)
40" LED Monitor
40" LED Monitor
Hi Jason,
I had missed it C05CCE,C-GJDT,ES-015,Lancair ES,T & J Chemello
ACA7192 CYYZ-SKBO
CYYZGUY
Hi Alan, another unknown with no fields populating.
A7D342
N603KE
regards,
Jason
40" LED Monitor
40" LED Monitor
Hi Jason,
A7D342 is not allocated by the FAA.  However N603KE is allocated A7D34A and is in the d/b as such so looks like it is miscoding.
Evening Alan,
VLG3634 : LEIB-LSZH
TRA2TL : EHEH-LEAL not LPPT-EHEH as given in d/b.
WZZ5VC : not sure of it's route but it is certainly not ENTO-EPSC as given in d/b but probably LEMG- somewhere as it has just flown over here !
Hi Ian,
Thanks again, it is LEMG-LROP, at least for the next couple of weeks until they change again.
X
Unknown from HKT area yesterday
* 881E85        2014/07/06 22:38:02
X
X
I think that 881E85 is the hex of HS-GTE B734 of City Airways but I cannot find any confirmation.
Afternoon Alan,
EZY82HU : LEAL-EGKK
VLG3600 : LEIB-EDDM
LOT7602 : LEMG-EPWA
Alan,
Also note that Ryanair would appear to be using EI-EXK A320-232 c/n 2502 leased in from Livingston.
