Started by orkney, May 31, 2014, 11:20:28 AM
0 Members and 7 Guests are viewing this topic.
Afternoon, the unknowns from Sunday:
* 126500        2014/07/06 08:35:37
* 12FE7C        2014/07/06 08:35:37
   3C6DC3        2014/07/06 18:27:55
   3D3362        2014/07/06 12:22:31
* 3FEE5D  DMDJJ      http://www.na3t.org/air/photo/DNC01365
* 3FF2F0        2014/07/06 10:17:24
   4B1781        2014/07/06 17:24:08
   50004D        2014/07/06 11:00:21
   50004D        2014/07/06 13:31:44
   800384  JAI121   EGLL-VIDP                                    Bad packet
* AA458B        2014/07/06 20:27:26
Regards Ingo
Hi Ingo,
126500 no country allocation
12FE7C no country allocation
3C6DC3 not current
3D3362 decodes to D-ERSC unknown to me
3FEE5D,D-MDJJ,,B&F Funk FK-14 Polaris
3FF2F0 unknown to me
4B1781 not assigned
50004D T7-AHB, nothing further
AA458B not assigned
Evening Alan,
SAS1802 : LEAL-ESGG
ASL6218 : LYBE-LEAM (Interestingly still appearing as JAT6218 on the airport arrivals board).
BER225P : LEMG-EDDL
CYYZGUY
#425
Hi Alan, an unknowns to me this evening..
Mode-S C004B4
Flight ID = G5K9650
Mode-S C036D0
Flight ID = CFUTR
No fields populating, not even "status"
ACA7190 Mode-S 4950D3  Another Euroatlantic,  No route, see if it needs to be updated..
http://flightaware.com/live/flight/ACA7190
regards,
Jason
40" LED Monitor
40" LED Monitor
Michel
Alan,
NAX35AP ESGG-LEPA
TRA1407 EHAM-LGIR
TRA69F EHAM-LGIR
CND191 EHAM-LTBJ iso EHAM-LTBS
Michel.
Jason,
Mode-S C004B4 decodes to C-FBUH, nothing on the Transport Canada website either current or historical.  However the flight ID may suggest that it is GL5T c/n 9650.  Was it on the ground or in the air?, may have been powered up on the ground for pre-flight checks.
C036D0,C-FUTR,29-0405,Mooney M20R Ovation 2 GX,Automotive Analysis Limited
ACA7190 CYYZ-SPIM
CYYZGUY
Hi Alan, good call on that one C-FBUH was showing as "Ground" the entire time.  So what you are saying may be true.
regards,
40" LED Monitor
40" LED Monitor
Xon
Many thanks for the update Xon.
Afternoon, the unknowns from Monday:
* 3C4820        2014/07/07 15:17:26
   3C6301  BER818Q  EDDT-EDSB     bad packet
* 3C651D        2014/07/07 14:31:20
* 3CC1C8  DCARO    http://www.aerointernational.de/business-aviation-nachrichten/erste-sovereign-fuer-aerowest.html http://www.planespotters.net/Aviation_Photos/photo.show?id=465247
* 3E9965        2014/07/07 08:21:29
* 3E9965        2014/07/07 13:40:23
* 3EAA37        2014/07/07 09:43:14
* 3EAA37        2014/07/07 17:32:38
* 3F417D  GAF787   EGWU-LFBD                                             2014/07/07 09:01:34
* 3F417D  GAF787   EGWU-LFBD                                             2014/07/07 17:30:15
* 3F564E        2014/07/07 08:48:52
* 3F6229  SHOCK1                                                         2014/07/07 07:41:29
* 3F6229  PACK1                                                          2014/07/07 12:43:22
* 3F739D  NITRO3                                                         2014/07/07 08:30:15
   3F8D6C        2014/07/07 08:02:47
   401080        2014/07/07 20:08:32
* 42409D        2014/07/07 22:27:57
* 43EA0A  MYSKY                                                          2014/07/07 11:45:57
* 43EA0A  MYSKY                                                          2014/07/07 17:12:21
* 440601        2014/07/07 09:38:12
   471EAF  WZZ1XN   EGGW-LROP      bad packet
   473403  WZZ86Q   EHEH-LHBP      bad packet
   484157        2014/07/07 21:04:46
   484446        2014/07/07 17:23:43
* 4CA2F6        2014/07/07 17:22:44
   4D00FD        2014/07/07 14:00:23
* AAC944        2014/07/07 10:49:41
Regards Ingo
Michel
Alan,
VLG6295 EHAM-LIRF iso LFPO-LIRF
Michel.
Hi Ingo,
3C4820 doesn't decode
3C651D  doesn't decode
401080 unknown miscode
43EA0A unknown to me
440601 doesn't decode
484157 doesn't decode
484446 not current
4CA2F6 not current
4D00FD unknown to me
AAC944,N7940L,M-992,Beech A23A Musketeer Custom III,Jerry Coggeshall  ??
