Started by orkney, May 31, 2014, 11:20:28 AM
Afternoon, unknowns from Wednesday:
   002280        2014/07/09 15:10:35
* 3944F6        2014/07/09 06:02:23
   3C4DD3        2014/07/09 18:34:56
   3C5EFB        2014/07/09 05:43:43
   3E3714  BBF130                                                         2014/07/09 13:31:01
* 3E9793  GAF320                                                         2014/07/09 06:54:02
* 3EB6A0  GAF068                                                         2014/07/09 06:55:47
* 3F4164  PACK2                                                          2014/07/09 07:51:54
* 40107F        2014/07/09 17:14:34
   451D81        2014/07/09 15:08:12
   47A741  NAX2MC   EKCH-LFMN      bad packet
   4840D7        2014/07/09 11:38:08
* 48417E        2014/07/09 05:30:22
   48ADA7        2014/07/09 19:13:52
   4B168A  SWR177Y  LSZH-EKCH   bad packet
   4BA907        2014/07/09 07:55:30
   4BA907        2014/07/09 11:20:14
* 4C284C        2014/07/09 11:16:21
* 4CA614        2014/07/09 10:18:38
* 502C6F        2014/07/09 15:28:23
* EBAA37        2014/07/09 08:32:53
Regards Ingo
Afternoon Ingo,
002280 miscode unknown to me
3944F6 decodes to F-GRHW unknown to me
3C4DD3 not current
3C5EFB doesn't decode
3E3714 decodes to D-IMBC unknown to me
40107F not current
451D81 unknown to me
4840D7 not current
48417E doesn't decode
48ADA7 unknown to me
4BA907 unknown to me
4C284C  unknown to me
4CA614  unknown to me
502C6F unknown to me
EBAA37 unknown miscode
Evening Alan,
The following 3 aircraft are currently leased from FlyDubai to Ryanair for the summer. Unfortuantely, I do not know their new hex codes :
A6-FDD B737-8KN c/n 40234 leased to EI-FEB.
A6-FDE B737-8KN c/n 40235 leased to EI-FEC.
A6-FDF B737-8KN c/n 40236 leased to EI-FED.
Easyjet's new A320 c/n 6194 G-EZWX arriving now at LEAL from EGKK.
Hi Ian,
EI-FEB 4CAB93
EI-FEC 4CAB94
EI-FED 4CAB95 all in the d/b for around a month
Morning Alan,
Indeed they are. Forgot to check.
Hi Alan
Hex 260701 i/d EF2000EF has been thundering around me. Wonder if it's practising for RIAT or Farnborough. Whatever, it's not populating.
Hi Rod,
The flight ID suggests that it is a EUFI, I would imagine out of Warton but the miscode it is using is unknown to me
Judwin45
Hi Alan
344484, CASA333 just gone North over Exmore, any other info please.
Keith
5 miles south of EGDY
#459
Hi Keith,
344484 is EC-333 which is to become G-VYGJ with AirTankers and then ZZ339 Voyager KC3 with RAF in due course.
flygfantast
Not populating from yesterday:
33FE14 MM62160, Piaggio P-180AM Avanti, c/n 1024, Italy - Air Force
The "mystery" M-YSKY, 43EA0A seen twice today (to and from Isle of Man).
Niklas
Cable: Ecoflex-10 (10m+1m)
Thanks Niklas,
The mystery plane is at least on Bones Isle of Man page no even if it only the hex and registration, getting there slowly.
I'm leaving Spain very early in the morning to return to Scotland and will be off line more or less until Monday evening.  Orkney Andrew will look after you in the meantime.
CYYZGUY
40" LED Monitor
40" LED Monitor
orkney
Hello Jason
That one is done now.
Andrew
