Started by orkney, May 31, 2014, 11:20:28 AM
Morning Ian, thanks again
Out of Gostomel on delivery to Cubana as CUB1461 is 0B06B3 CU-T1715 Antonov An-158 c/n 20105
Michel
Alan,
TRA721 EHAM-LTAI
TRA5805 EHAM-LGTS
TRA1511 EHAM-LTBS iso EHAM-GCLP
TRA2951 EHAM-LTAN
TRA538 LEMG-EHAM iso LEMG-EHGG
TRA571P EHAM-LBBG
TRA5215 EHAM-LICC
TRA922 LTAI-EHAM iso LTAI-EHEH
TRA1245 EHAM-HEGN
TRA1805 EHAM-LGKO
TRA521 EHAM-LGKO iso EHAM-GCLP
TFL787 EHAM-LTBJ iso EHAM-LCLK
CND497 EHAM-LGKO
CAI506 EHAM-LTFE
DLH1A EHAM-EDDF iso LFMN-EDDM
UAE9997 OMDW-EHAM-KORD iso OMDW-EKCH-KORD
Michel.
Many thanks Michel
BTW I believe DLH1A is one of a number of DLH callsigns which is used on more than one route, causes me nightmares.
Michel
Is it? In this case DLH1A is DLH991.
Michel.
That's correct Michel, I will need to look out for the other one and advise what the ticket number is.,  However we can only have one of the same call sign so when the wrong one comes up it is automatically marked as rejected for being wrong and this affects both routes with the same radio call sign.
flygfantast
4AAC8B SE-KDK, Beech B200 Super King Air, c/n BB-909, Bromma Air Maintenance
4A914B SE-DJK, Dassault Falcon 7X, c/n 59, Bromma Business Jet AB (ex G-PVHT)
Niklas
Cable: Ecoflex-10 (10m+1m)
Thanks again Niklas, appreciated
Evening Alan,
Just had come over Emirates Skycargo flight EK9768. The d/b shows the route as KJFK-EDFH-OMDB but the route today is DNMM-DGAA-LEZG. Having looked into it, it would appear that Emirates are using the same flight ID for different routes depending on the day of the week therefore probably best to delete any route information for this flight ID from the d/b.
Cheers ian, quite common for cargo flights
paul tricker
440770  NLV554                                                         2014/08/09 20:44:59
440770  NLV553                                                         2014/08/09 22:45:39
This was OE-IDP  A320-233  c/n 2118  White, leased to Livingston
Paul
Michel
Alan,
TFL921 EHAM-HEGN iso EHAM-HESH
Michel.
Afternoon Alan,
SWR2117 : LEMG-LSZH
WZZ5BK : LEAL-LHBP
