Started by orkney, November 12, 2014, 11:19:39 AM
#1395
Morning Neil,
3C0C90 decodes to D-ATTR unknown to me
Hello Alan,
Unknowns from Wednesday :
10204A nothing more
3C720B nothing more
400950 was G-EZJK Bis nothing about a new one
4CAB0D nothing current
MILs:
* 3E965D  GAF224                                                         2015/02/04 08:30:24
* 3F76DB  PACK2                                                          2015/02/04 13:50:15
Btw: 3C0C90 was posted by Neil not me.
Regards Ingo
Thanks Ingo,
Reply corrected
Noting to add to your unknowns and the 2 mil added
Afternoon Alan,
VLG7392 : LEAL-DAOO
EXS271 : EGNM-LEAL
Out of Toulouse and looking set for a UK airspace visit is 896412 A6-AOF Airbus A320-214 c/n 6444 Air Arabia
Northern Watch
Good afternoon Alan
A couple of issues found today:
3C8459 / D-BABY picture showing old Vickers not a Dornier.
3F9572 / c/s GAF028 German Tactical code not populating.
Keith
Thanks Keith, hopefully sorted the photo problem and have added the tactical code.
Out of Toulouse as CQH1656 is 780DC5 B-1656 Airbus A320-214 c/n 6452 Spring Airlines
Michel
Alan,
ABW326  EHAM-UUEE iso EHAM-LIMC-UUEE
Michel.
jim_stockwell
Hi Alan
Is there a problem with the database update programme?
I have been trying to do an update but it has gone to sleep on the routes processing table, as it has now been stuck for over over 15 minutes!
Jim
Once it has downloaded it is with the software and not the download itself. it would appear to have hung and I would suggest that you start the download process again Jim.
Afternoon Alan, Unknowns from Thursday :
03C799 no country allocation
0CD050 same as above
 3D2E10  DEPRS received two times yesterday. Still no luck with the details
3D40D7 D-EWUP Morale Rallye determined by: http://acbh.de/index.php?id=379&L=iuxuvxhpbedhzyw&print=0 and this document Fragebogen DG1000Turbo https://www.google.de/url?sa=t&source=web&rct=j&q=%22D-EWUP%22%20morane&ei=UbzUVKn9OYvxULONguAH&url=http://test.acbh.de/index.php%3Fid%3D156%26eID%3Ddam_frontend_push%26docID%3D233&ved=0CCEQFjAA&usg=AFQjCNHNLnTXJVHj86wHC0wjp8A2Gf1_4g&sig2=L2vtcmS6J3qkeVx_tyBTKQ
3FF2D6  DMMSE still no luck with the details
4001DF nothing more
48405C was PH-BTE B733, nothing about a new one
4AB523  nothing more
780DC5  CQH1656 has not populated during my yesterdays run. Will try again later.
Regards Ingo
Supplemental:
Has populated now.
