Started by orkney, November 12, 2014, 11:19:39 AM
jim_stockwell
Hi Alan
Have left it about an hour and tried to run the update again, but with the same results. It hangs up on the processing routes tables.
Jim
PS I have not tried shutting down yet, so will do that now and try again
Hi Ingo,
3D40D7 D-EWUP Cessna T206H Turbo Stationair c/n T20608576
D-EPRS plots but no info found
4AB523 decodes to SE-MIC.  It flew from Straubing to Vasteras using flight ID SWC964 so hoping Niklas can find out some info.  Have been advised that a Vasteras based N**** registered P46T normally uses the ID but nothing on the Swedish register yet.
Nothing on the others
The CQH populated for me yesterday evening when I caught it over Belarus.
Hi Jim,
Yes I would suggest closing down RB and restarting.  I downloaded the update this morning  with no problems.  Also did the same after your reply and again it downloaded and installed with no problems
jim_stockwell
Hi Alan
Shut things down and retried the update--worked like a dream!
Who knows what goes on in the the mind of a computer and its software.
Jim
Something must have got clogged up or corrupted in the process Jim, glad all is OK now
Xon
X
#1417
* A16CA2        2015/02/07 13:22:41
A16CA2 decodes to N191HS but this is actually A16C22 N191CP FA50 miscoding on departure DWC!
X
Many thanks X, they like making it hard for us!
On delivery to Nepal Airlines as RNA241 is 70AFB9 9N-AKW Airbus A320-214 c/n 6445 http://www.rb24.com/RNA241
Morning Alan, some unknowns from Friday:
076080 nothing more
3E27F0  DIGIA http://www.flugschule-dortmund.de/charter.html and maybe some more...
3E3506 nothing more or MIL?
3FAAF7 nothing more or MIL?
Have a nice Weekend!
Morning Ingo,
D-IGIA looks good to me but I cannot find a c/n yet so added without
3E3506 decodes to D-ILGW but I can only find info on the previous C404
3FAAF7 is mil
X
They should read like this
IRM066   OMDB-OIIE     EP-MNK     A306  Mahan Air            2015/02/06 20:45:51
IRM067   OIIE-OMDB     EP-MNK     A306  Mahan Air            2015/02/06 19:10:38
X
Evening Alan,
SX-BHR c/n29234 B737-5L9 in d/b as wfu/stored (ex Hermes Airlines) has just flown over operating for Air Mediterranee.
