Started by orkney, November 12, 2014, 11:19:39 AM
Northern Watch
Good evening Alan
Just noticed OY-RJC is in the db as WFU but today it has been flying SAS flights. Recently out off EGNT as SAS544.
Keith
Thanks Keith, amended. BTW SAS have received approval to acquire Cimber and the transfer is to be implemented 1st March http://www.cimber.com/
CYYZGUY
#1547
40" LED Monitor
40" LED Monitor
Northern Watch
Hi Alan
Thank you for your answer regarding the Cimber take-over.  Another picture problem just occurred with SE-RJT showing as the old MD82 rather that the B737.
Keith
mdobuk21
Hi guys , is there a file for up to date flight routes?
Mark
CYYZGUY
#1550
40" LED Monitor
40" LED Monitor
CYYZGUY
A74DAA
N57SK
No Other info populating..
Jason
40" LED Monitor
40" LED Monitor
Thanks again Jason for the route info.
N57SK is CL30 N83JJ reregistered
Keith, have hopefully amended the d/b so as the old one doesn't show again
Mark,
The routes database comes as part of the Navdata update which is produced each day.  All or any of the tables can be updated to suit your needs airports, acype,  Aircraft, airlines and routes.
CYYZGUY
40" LED Monitor
40" LED Monitor
diddyboy
Hi Alan
A couple of Test Regs today, I think the first is from Dassault and the second is Airbus A330 F-WWCY.
* 38067A  MEDOC02                                                        2015/02/16 14:59:18
* 380D1A  AIB01CY                                                        2015/02/16 15:00:39
Also can you amend the following from A346 to A330 as I can confirm that it was an A330.
380C1A AIB03CP  F-WWCP Airbus test
Neil
Hi Neil
38067A F-WWJR, last 3 have been Falcon 2000's
380D1A F-WWCY is the 4th A333 with the test registration and should be c/n 1611 due to become HL8025 shortly
380C1A F-WWCP is the 4th A333 with the test registration and should be c/n 1604 due to become 4R-ALN shortly.
Afternoon / Evening, Sundays unknowns
* 34428A
* 394C35        2015/02/15 14:57:24
* 3C48D8        2015/02/15 12:45:37
* 3C7DCE        2015/02/15 15:39:37
3FF14B  DMFEG
* 471EC9        2015/02/15 06:46:18
* 4C0059        2015/02/15 09:20:51
* A04444        2015/02/15 11:58:51
Extremely bad webspeed today. So no investigation possible.
Regards Ingo
