Started by orkney, November 12, 2014, 11:19:39 AM
CYYZGUY
A89584
no other info populating....
regards
Jason
40" LED Monitor
40" LED Monitor
Its a miscode that's been around for a while Jason and I don't know the aircraft involved.  A89584 decodes to N652PY which isnt assigned and I cannot find any reference to it having been assigned previously
Hi Ingo,
34428A was being used by EC-337 for Saudi Air Force which my d/b gives as being on MRTT conversion since April last.  Unknown to me if this is still the case.
394C35 decodes to F-GTBV unknown to me
3C48D8 decodes to D-ABFX unknown to me
3C7DCE decodes to D-AONN unknown to me
3FF14B  D-MFEG unknown to me
471EC9 unknown to me
4C0059 unknown to me
A04444 not assigned by FAA
CYYZGUY
40" LED Monitor
40" LED Monitor
CYYZGUY
40" LED Monitor
40" LED Monitor
Thanks Jason, all your country folks escaping the cold for a couple of weeks.
CYYZGUY
Yes for sure, it had been -25C and -27C the last 2 nights.   With Wind Chill factor, close to -40C!!
40" LED Monitor
40" LED Monitor
CYYZGUY
40" LED Monitor
40" LED Monitor
X
#1569
* 732823        2015/02/17 00:26:55
* 732823        2015/02/17 02:34:32
732823 should be EP-JAC
X
Hi X
I have been getting 732823 for weeks and it does decode to EP-JAC but I have no idea what it could be, I can find nothing on it.
X
#1572
THY6776   LTBA-OMDW               9M-MUC     A332  MASkargo             2015/02/17 10:15:47
THY6776   OMDW-LTBA               9M-MUC     A332  MASkargo             2015/02/17 12:17:20
Not sure how you will mark it LTBA-OMDW-LTBA?
X
Unknowns from Monday :
0948A0 no country allocation I presume a bad packet received
3FEC20  DMTTB no luck with the details
48417D was PH-RXB E145  nothing about a new one
48B0E9 nothing more
* 780D7D  CBJ1643 Capital Airlines Airbus on delivery. Therefore already added?
ACB893 decodes N919EW, currently not assigned/reserved by FAA
MILs:
* 3EAA26  GAF799                                                         2015/02/16 16:46:50
* 3F4BFE        2015/02/16 14:32:17
* 3F8FE9  TA127                                                          2015/02/16 09:33:40
* 3F8FE9  TA127                                                          2015/02/16 11:22:02
Regards Ingo
Thanks X
LTBA-LTBA-OMDW and it should show on your myflights as LTBA-OMDW-LTBA
