Started by orkney, November 12, 2014, 11:19:39 AM
CYYZGUY
Hi Alan, can you shed any light on this..
Mode-S A9DB8D
Flight ID BSK398
Reg N734SX
Coming up as a Cessna 172, Miami Air, with routing etc.
This cannot be correct.
Jason
40" LED Monitor
40" LED Monitor
Hi Jason,
A9BD8D doesn't indeed decode to N734SX the C172.  However the BSK call sign indicates that this is a miscode and I would suggest that it is being used by N732MA which is allocated A9D38D.  This may not be the case however and it may be one of the others in the BSK fleet.
BSK 398 is routing CYUL-KSJC and has been used on 5 different routes in the past two weeks.
CYYZGUY
#1817
Thanks alan, here is another one, Cubana, using its T204 jet
Flight ID is coming up as CUB350, on approach to CYYZ as we speak.
Mode-S 7277A8
I cannot find any routing on it..  Can you?
Cubana by CYYZGUY, on Flickr
Jason
40" LED Monitor
40" LED Monitor
Jason
CUB1981 was due to arrive Pearson at 1341 EST from MUHA operated by the T204, landed around 20 minutes ago.
Morning, the only unknown from Sunday:
868002 nothing more
Regards Ingo
Morning Ingo,
868002 decodes to JA7362 which isn't allocated
Alan,
EXS584 : LEAL-EGNT needs recycling. Route is in d/b but not showing.
shark319
Wizz Air March update.
WZZ607 (W6 3101) LROP-EDDN
WZZ635 (W6 3102) EDDN-LROP
WZZ48   (W6 3369) LRCL-EDDN
WZZ217 (W6 3370) EDDN-LRCL
Günter
X
New Rossiya f/n s which suggests ULLI to somewhere in Moscow area and return
SDM6128  UUWW-ULLI                EI-ETO     A319  Rossiya - Russian... 2015/03/02 10:56:18
SDM6123                                     EI-EZC     A319  Rossiya - Russian... 2015/03/02 07:43:00
SDM6124                                     EI-EZC     A319  Rossiya - Russian... 2015/03/02 09:39:06
X
X
Two new f/n's by Redwings
IN141                    RA-89021   SU95  Red Wings            2015/03/02 01:45:24
IN142                    RA-89021   SU95  Red Wings            2015/03/02 07:11:
X
X
A few more unknown f/n's would suggest on three Saratov to MOW...but which MOW, probably UUDD?
6W758                    RA-42326   YK42  Saravia - Saratov... 2015/03/02 09:15:47
6W762                    RA-42326   YK42  Saravia - Saratov... 2015/03/02 19:06:11
6W764                    RA-42389   YK42  Saravia - Saratov... 2015/03/02 22:24:15
GOZ9756                RA-42385   YK42  Volga Aviaexpress    2015/03/02 12:31:27
X
X
#1827
AFL1320 UUEE-ULMM VP-BDN     A319  Aeroflot Russian ... 2015/03/02 07:11:27
AFL1332 UUEE-ULAA  VP-BQW     A320  Aeroflot Russian ... 2015/03/02 08:18:51
X
X
Some more RusLine
7R107     VP-BVB     CRJ1  RusLine              2015/03/02 09:10:46
7R108     VP-BVB     CRJ1  RusLine              2015/03/02 11:01:47
7R164     VP-BVK     CRJ1  RusLine              2015/03/02 11:44:46
X
paul tricker
one non populator from yesterday..
43E95A  MCFLY                                                          2015/03/02 15:32:04
a quick search of the web reveals
M-CFLY    DF50EX    320   ex M-VGIN
Paul
