Started by orkney, November 12, 2014, 11:19:39 AM
#240
Many thanks John.
For info DAL132 and DAL133 were corrected in the d/b 16/11.  DAL132 now further amended with KMSY added
John Racars
thank you for the feedback! But........
DAL133 is still in the D/B with the wrong data.
An other question: did you processed my message #151? I saw this morning wrong data (DAL74) again as well. Maybe something went wrong with processing the corrections?
Kind Regards, John
13 NM East of EHAM
ANRB:
Version: 3D - 5.00.072
PC: Windows 7 SP 1 - 64 bit
RadarBox24 station: EHAM4
#242
John
DAL133 is correct see shot from my d/b explorer attached note date of change
DAL74 is correct as per 151 see shot from my d/b explorer attached, note date of change
Maybe your d/b is needing updated.  Mines was updated this morning.
John Racars
QuoteMaybe your d/b is needing updated.
Alan,
I am sorry. I thought this happen automaticly.
I will update my D/B immediately.
Thanks again.
Regards, John
13 NM East of EHAM
ANRB:
Morning Alan,
TOM52C : LEAL-EGCN
Morning Ian,
Only 3 TOM inbound this morning
Alan,
If it's the same as the summer schedules, it's usually Tuesday morning and Saturday evening for the busy times.
Thanks Ian, I will be watching for them after the football, Scottish Cup today.
D-AKNG GWI8043 EDDL - EDDT
Ingo,
Added the GWI however  the TUI doesn't appear on the Tegel departure board, positioning flight maybe?
That's what I've figured out too. The TUI has arrived with this number from Pamplona and is now flying to another airport for the next flight with pax.
For your information Alan, OH-JRD has populated after second run of "populate".
Yes, helps if I add it in correctly. -))
Ian, no more Thomson arrivals today.
