Started by orkney, November 12, 2014, 11:19:39 AM
John Racars
Allan,
Airportdata not in the D/B:
Name: Atyrau International
Land: Kazachstan
IATA: GUW
ICAO: UAGZ
13 NM East of EHAM
ANRB:
Version: 3D - 5.00.072
PC: Windows 7 SP 1 - 64 bit
RadarBox24 station: EHAM4
M
* 33FE28  IAM1495
It is P180 MM62163
John Racars
QuoteAtyrau International Airport is in the database as ICAO  UATG
Alan, thank you; in that case:
FN NO ND NV || REMARKS NO ND NV
Suggestion(s)
to correct:
KZR904 EHAM UATG || i.s.o. EHAM UAGZ
13 NM East of EHAM
ANRB:
John Racars
New:
DCS201 EGSS EDDS
DNM5512 EYPA EHRD
GTI701 EHAM OMDM
HFY270 EGBB EDLP
MSX5520 HECA EBOS
SXY336 HKJK EBBR
Suggestion(s)
to correct:
BLX605 ENGM GCTS || i.s.o. ENGM LGRP GCTS
LAE2871 EHAM SBGR SBCT || i.s.o. KMIA SGES
13 NM East of EHAM
ANRB:
#278
Many thanks again John.
According to Flightaware  LAE2871 flew SEQM-KMIA-EHAM http://uk.flightaware.com/live/flight/LAE2871
Also don't normally add it business flights line DCS as the same flight ID can be used on numerous routes
John Racars
#279
Alan,
Apparently an extended tour. Impossible to get this kind of flights to appoint correctly in the database.
BTW: QTR flights (4, 24, 28, 194, 8102) don't show there flightinfo anymore! What is going wrong?
Kind Regards, John
13 NM East of EHAM
ANRB:
John,
I have no idea on your QTR flight.  Two of them, QTR28 and QTR8102  I picked up and as can be seen from this shot of my reporter, they populated OK for me.
John Racars
I am sorry Alan.
I can't explain. Just a minute ago apears QTR008 on the screen....
....no route info.
Regards, John
13 NM East of EHAM
ANRB:
John Racars
#282
Alan,
Sorry, no flight info about QTR flights in the interface and on the map.
All other companies are "normal".
When I have a screen with QTR flights on it I will sent this immediately.
Edit: QTR1 looks normal now. (After I closed and restarted RB.................)
New:
AZG623 UKBB EGSS
DLH4PN EDDM EHAM
GMI3340 EDDV GCLP
GWI71B LFPG EDDH
HFY272 EDLP EGBB
JAF1AX GCTS EBLG
MSX5521 EBOS HECA
TRA2V EDDT EHEH
Suggestion(s)
to correct:
CFG7MA GCRR EDDV || i.s.o. LGIR EDDF
Reg. John
13 NM East of EHAM
ANRB:
Thanks again, John.
I have no idea why QTR is blank and all other are OK.  See from the attached all my QTR's on the network are showing route info and why it should just start occurring for you today.
Michel
Alan,
NVR144 GCRR-LPFR-ESSA iso GCRR-LPFR-ENGM
Michel.
