Started by orkney, November 12, 2014, 11:19:39 AM
Nothing on any of those Ingo
John Racars
#302
FN NO ND NV || REMARKS NO ND NV
Suggestion(s)
to correct:
GWI7E EDDL  EGLL || i.s.o. EDDV LGIR
13 NM East of EHAM
ANRB:
Version: 3D - 5.00.072
PC: Windows 7 SP 1 - 64 bit
RadarBox24 station: EHAM4
John Racars
Allan, I am sorry. Type error from my side. "LGLL" should be "EGLL" in this case.
I corrected it in my message above.
13 NM East of EHAM
ANRB:
No bother John, I recognised the typo
John Racars
Thank you Alan!
Showing my report of this evening below it looks WZZ takes their time again to take up the hobby to change flightid's again:
New:
BCS815 EDDP EBBR
WZZ1CP EVRA EGCN
WZZ2HZ EPWR LFOB
WZZ38J EYVI EGGW
WZZ3UC EPGD EGCN
WZZ8WG EPKT EGCN
WZZ8ZY EPLB EGGW
WZZ9PF EGCN EPPO
Suggestion(s)
to correct:
WZZ727 LYBE LFOB || i.s.o. LRCL LEMD
13 NM East of EHAM
ANRB:
Thanks again John, WZZ seem to change a number of their flight ID's on the first of each month.  I have spent this evening working them out and adding them in
Morning,
D-AHJX BER863 EDDV - ? Flight not in departure list. So possibly a positioning flight.
Morning Ingo,
It went to EDDT, I don't know whether its scheduled or no, this morning was the first it has been picked up but will add it in just in case.
Morning Alan,
Usual Tuesday morning bedlam at LEAL. Will see if the Vietnamese CASA reappears. Meanwhile :
NAX1BY : ESSA-LEAL
Thanks Ian,
Off to Prestwick shortly.  4 A4 Skyhawks due at 1020 plus Kuwaiti C17 in from yesterday and not a cloud in the sky, good times
CYYZGUY
#312
Hi Alan, confusing one here for me this morning.
FJM155  Sitting on the ground at CYYZ
No Routing showing, however flight aware shows this..
http://flightaware.com/live/flight/FJM155
Also, UAL501, showing no routing, but it appears to be all over the place..
http://flightaware.com/live/flight/UAL501
regards,
Jason
40" LED Monitor
40" LED Monitor
Hi Jason,
I have been looking at the Pearson website and it is only showing FJM141 MKJP-CYYZ arriving late at 0910 local and departing as FJM140, maybe they have the wrong details in the aircraft FMS.
As for the UAL501 this shows one of the problems I have with United flights.  For most of the week it operates KBOS-KOPRD but it is also used to operates KORD-KSAN and KRSW-KEWR on two different days each week.  This is the reason most UAL flights are left without route info
Evening, the unknowns from Monday:
4B19E4 nothing more
86D9FE nothing more
9800CF no allocation
A895E9 N652TZ not assigned by FAA
B803CF no allocation
EA00CF same as above
EB03CF no allocation
FFFBB8  3  0   no allocation
MILs:
* 3EA928  GAF037                                                         2014/12/01 09:14:38
* 3EA928  GAF037                                                         2014/12/01 10:49:00
* 3F665D  GAF634                                                         2014/12/01 11:22:32
* 3F8014        2014/12/01 13:34:57
* 3F8014        2014/12/01 17:06:55
* 3F8014        2014/12/01 17:41:21
* 3F81B7  IRON1                                                          2014/12/01 09:08:06
* 3FA251  TA60                                                           2014/12/01 09:15:16
* 3FA251  TA60                                                           2014/12/01 11:12:44
* 3FA72B        2014/12/01 08:48:40
* 3FA72B        2014/12/01 09:24:34
* 3FACAA        2014/12/01 19:06:17
* 3FACDD        2014/12/01 14:27:37
