Started by orkney, November 12, 2014, 11:19:39 AM
0 Members and 6 Guests are viewing this topic.
Evening, the unknowns from Tuesday:
382D1A F-WWOL Eurocopter test reg. (source FR24)
3C4439 nothing more
3C48DD nothing more
3C6DDA D-AKNZ, I've found no active airframe using this reg/hex
430099 nothing more
45B857 nothing more
A20431 N229TZ not assigned by FAA
MILs
* 3F7B4D        2014/12/02 13:32:16
* 3F7B4D  MONSTR2                                                        2014/12/02 15:41:03
* 3F85DD  PACK1                                                          2014/12/02 13:37:37
* 3F85DD  PACK1                                                          2014/12/02 18:33:03
* 3F920C        2014/12/02 08:03:51
* 3F9624        2014/12/02 08:36:33
* 3F9624  LANCE4                                                         2014/12/02 13:14:11
* 3F98D3        2014/12/02 08:53:31
   3F9FCA        2014/12/02 13:11:30
* 3FAFC0        2014/12/02 13:40:54
* 3FBAB3  MONSTR1                                                        2014/12/02 14:42:18
* 3FBAB3  MONSTR1                                                        2014/12/02 15:45:15
Thanks Clive, C56X now added to the database
Evening Ingo,
Nothing to add to your unknowns, added in the Tactical and the Eurocopter test registration.
can you check this one please:
Hasn't populated after three cycles.
Thanks!
flygfantast
Cable: Ecoflex-10 (10m+1m)
Hi Niklas,
this German MIL (3FA8CD) has already been added to the database. I had it yesterday, with GAF007 flight id. During populate cylce this airframe was added to my local database.
Hi Niklas,
Got if from your log and added this morning, nothing on AB0EF1 though
the mentioned MIL-TAC has populated now. Thanks again.
flygfantast
#339
Alan/Ingo
Niklas
Out of XFW as THD8904 is 885312,HS-TXR,6374,Airbus A320-232,Thai Smile
Afternoon Alan,
Just had come onto 'My Flights' RAM960U hex code 020110. However no other details are appearing on the grid ie no registration, aircraft details or silhouette. The flight is showing on the map and the route given GMMN-LEBL.
Afternoon, unknowns from Wednesday:
1666BF nothing more
39856F nothing more
461EA2 nothing more
471E1A nothing more
4B003F nothing more
4BAB30 nothing more
4CA1A2 nothing more
FB30FF no country allocation
MILs:
* 3F4314  PACK3                                                          2014/12/03 13:36:29
* 3F4A9F        2014/12/03 13:03:44
* 3F8351  GAF608                                                         2014/12/03 09:37:40
* 3F8351        2014/12/03 11:07:26
* 3F8351  GAF608                                                         2014/12/03 11:48:29
#343
My mistake Ian, had it in the d/b with the wrong hex, now corrected.  Its one of their new E190's CN-RGO
Evening Ingo,
Nothing on your unknowns and the 3 TAC added
