Started by orkney, November 12, 2014, 11:19:39 AM
Out of Shannon on delivery earlier 4891B2 SP-ENT Boeing 737-8AS c/n 29926/722 Enter Air
X
New Bahraini descending from 10000 down to somewhere nearby
* 8940DF        2014/12/21 18:35:26
X
Flieger_NDS
#648
Quote from: Runway 31 on December 19, 2014, 07:31:14 PM
D-CFMU isn't FL-906 as it recently became N715A with Aramco earlier in the month.
You are definitely right, D-CFMU and N715A were airborne at the same time on Friday, my bad. I am certain D-CFMU is FL-948 (ex N5048K) which got canxd to Germany on 12/12/14. Following the temporary reg it will become SP-TPU, there is a nice proof and you can read the future reg under the sticker. After special mission conversion it will belong to the same organisation like the two L410 SP-TPA and SP-TPB.
https://www.flickr.com/photos/99346508@N02/15875596630/
Wow lovely colours Gunter and thanks for the information.  I would suggest you are correct in your assumption regarding FL-948.
Michel
Alan,
JTG924 GCTS-EFHK
TRA403 EHAM-HEMA iso EHAM-HEGN
Michel.
X
#652
Yesterday it was 1331 miscoding, today it is 896C32  1332 SF34 UAEAF that has the wonky box
* 000032        2014/12/22 10:19:40
* 006C32        2014/12/22 09:52:27
* 806C32        2014/12/22 10:22:01
X
M
FCM8XA   EFHK   EDDF
FCM7BZ   EDDF   EFHK
FCM7VE   ESGG   EFHK
JTG923   EFHK   GCTS
TRA121   EHAM   EFRO
TRA737   EHAM   EFKS
Operator update for AN12 UR-CCP: Cavok Air
Morning,
the only unknown from Sunday is
EC03CC and that seems to be a damaged packet received...
No idea what that may be Ingo
Thanks X, it looks as thought that box could through out a lot more crap unless it is fixed
4K-SW008 AZG977 (7L997) LHBP - EGSS
4X-BAU AIZ461 (IZ461) LLBG - EDDB - LFPG
9A-CTJ CTN1842 (OU1842) BKPR - EDDL
9A-CTJ CTN1843 (OU1843) EDDL - BKPR
B-2453 YZR7493 (Y87493) ZSPD - ELLX
B-2453 YZR7494 (Y87494) ELLX - ZSSS
B-2476 CA01014 (CA1014) EDDF - ZBTJ - ????
D-ABBX BER677P EDDN - EDDL presuming a positioning flight, as it isn't in EDDNs departure list
D-ACNO GWI6990 (4U6990) LIMC - EDDL not in EDDL arrivals
D-ACNP GWI8093 (4U8093) EDJA - EDDT
D-ACNP GWI32Y (4U8092) EDDT - EDJA (posted before, but still the false LDZA-EDDK route info)
D-ACNP GWI72B (4U7090) EDDH - EDJA (posted before, but still false route info LDSP - EDLW)
D-ACNP GWI91E (4U7091) EDJA - EDDH (posted before)
D-AGWT GWI6905 (4U9605) EDDS - EDDL (but this time it went to EDDH)
D-AICC CFG9679 (DE109679) EGCC - EDDP (after such long time without any other flight, I think that this was a ferry flight)
D-AICN CFG0ZF EDDB - EDDF positioning flight
D-AIQF GWI6904 (4U6904) EDDH - EDDK
D-AIQR GWI6909 (4U6909) LHBP - EDDK
D-AIRU DLH9922 LH9922 EDDF - EDDB ferry or positioning flight
D-ASTV GMI1183 (ST1183) HESH - EDDL
D-ASTV GMI1182 (ST1182) EDDL - HESH
D-ASTZ GMI5015 (ST5015) HEGN - EDDH
D-ASTZ GMI5014 (ST5014) EDDH - HEGN
D-ASXA SXD4788  (XG4788) HEGN - EDDV
D-ASXK SXD4649 (XG4649) EDDK - HEMA
D-ASXK SXD4722 (XG4722) HEMA - EDDL
D-ATUF TUI255 (X3225) EDDS - EDDV
What's the problem with the D-ACNP flights?
Ingo,
Thanks for the route info.  Regarding the D-ACN* flights.  I did a check back and look to have missed the post that contains the information as I did not reply to it.  Updated now.
