Started by orkney, November 12, 2014, 11:19:39 AM
that is what I'd like to call "best case scenario problem"  for already posted and still not showing up routes.
Afternoon Alan,
VLG1390 : LEAL-GCXO
VLG3014 : LEBL-GCFV
Out of Toulouse as DKH6392 is 780CC4 B-1871 Airbus A320-214 c/n 6392 JuneYao Airlines
X
Unknown Aruba at 22000 for 20 minutes this morning. My Log says Aruba_P4-ABC but no a/c type etc
* 484357        2014/12/23 08:48:02
X
TC-JHA THY5862 (TK5862) EHAM - LTBA
The unknwons from Monday:
3CC54F nothing more
4A0095 nothing more
4BAA8B nothing more
4BEB20 nothing more
4CAA53 nothing more
Regards Ingo
X
The previous 484357 P4-ABC is now TS-INV CL604.  So either miscoding old ID or it is a new allocation which is unknown to me
Ingo,
Nothing on your unknowns and thanks for the route
Michel
Alan,
For the time being:
XLF240 LFPG-EFRO iso LFPG-LICC
Michel.
D-ABIP DLH1372 (-) EPWR - EDDF was used yesterday for this relation
LH1372 is usually EDDF-EPWR with flight id DLH1YA the way back it usually LH1375 (DLH5KV). Therefore there is in my opinion no need to add DLH1372.
D-ABMK BER388F ENBR - EDDL (not in EDDL time table)
D-AHFZ TUI825A (X36825) LBBG - EDDV
D-AICA CFG9678 (DE109678) EDDP - EGCC (ferry flight?)
D-AIDD DLH9924 (LH9924) EDDM - EDDB (special flight?)
D-ASXK SXD2859 (XG2859) EDDK - EDDM - GCLP
D-ATUM BLX685P (-) EDDV - ESGG (ferry to) in the morning
D-ATUM BLX686P (-) ESGG - EDDV (ferry back) in the evening
EI-RDC AZA418 LIML - EDDL (AZ418)
EI-RDD AZA406 LIML - EDDT (AZ406)
EI-RDI AZA420 LIRF - EDDL (AZ420)
EI-RDN AZA422 LIRF - EDDT (AZ422)
F-GTAL AFR173C LOWW - LFPG (AF1739)
F-GZHK TVF760 EDDT - LFRS (TO760 / TO3987)
F-HBXC AFR163N LFPG - EDDV (AF1638)
F-HBXC AFR361R EDDV - LFPG (AF1639)
G-EUXI BAW8RM (BA993) EDDT - EGLL
HA-LPS WZZ1XV (W61632) LFOB - EPGD
HB-AFG FAH8XF EDDK - EDDB not 100% confirmed
HB-AFG FAH7XF EDDB - EDDK not 100% confirmed
LN-NGF NAX31K (DY3581) LKPR - EKCH
LX-LGE LGL56B (LG9561) EDDR - EDDH
LX-LGG LGL51C (LG9451) EDDR - EDDT
OK-NEN CSA6766 (OK6766) LKPR - EHAM
OK-NEN CSA6767 (OK6767) EHAM - LKPR
PH-HZF TRA423E (HV5423) EHAM - LIRP
PH-XRA TRA560Z (HV6505) EHRD - LOWS
SE-LPV SWN6716 (PT6716) EDDK - EGBI
SE-LPV SWN6715 (PT6715) EGBI - EDDK
SP-HAD LLP8846 (P78846) GCFV - EPGD
SP-HAD LLP8845 (P78845) EPGD - GCFV
Many thanks for the route info Ingo.  I have not added the DLH9*** flights as these are non -scheduled and can change frequently.
I am not aware of EGBI, can you advise please
if you change the G with a K you will get EKBI and that's what the brain sent to the fingers, but unfortunately they decided to write EGBI.
Aha!!  I know that feeling well Ingo, thanks
X
#674
I doubt it is 484357 the CL60 now TS-INV ex P4-ABC at a constant 20,000 for 20 minutes
X
