Started by orkney, November 12, 2014, 11:19:39 AM
Thanks for the route Kenny
Regarding 3C6A24:
It indeed seems, that this one is 3C4A24 miscoded.
In July this year it has braodcasted this hex too. That time it took nearly one month to be fixed.
Have you processed my route amendment regarding GWI16F (one post before Kennys route request)?
Thanks Ingo, that's an old one reused
Northern Watch
Good evening Alan
A slightly belated Happy Christmas to you and yours.  Sadly to say that my netbook gave up on me a week or so ago but thankfully I had backed up mylog first.  Now running a Packard Bell netbook on windows 7 starter and thanks to the help from the forum everything loaded OK, except I think I have a problem with resizing the myflights and the aircraft picture screen. The symbol does not appear when you scroll over the screen between the two.  It look as if other people have had this problem with netbooks with this screen size/resolution. I  I am not to worried as at least I am back up and running.
One from today that did not populate:
A26B8B / N255RC / Ce560XL / c/n 560-5554 / Ocana Investments LLC
Keith
Hi Keith,
Merry Christmas to you and yours as well.
My colleague Orkney has added N225RC in earlier.
Regarding your netbook screen have a look at resize enable http://www.softpedia.com/get/System/System-Miscellaneous/ResizeEnable.shtml
Evening, some unknowns from Sunday:
3C4848 decodes D-ABBH nothing about a new one using this hex/reg
3D0B72  DECOW D-ECOW Reims Cessna F177RG Cardinal RG F177RG0028 Last Mk1EBed in  2011
3D33B6 nothing more
3FF38C  DMLPT still no luck with the details.
The problem that keith has had reminds me the fact, that my 24/7 laptop is now running for 722 days or 17300 hours without a break. I definitely should starting to put some money aside.
Unfortunately no time for the roots today.
Regards Ingo
Evening Ingo,
Only comment on your unknown is that my d/b suggests that F177RG0028 has been reregistered to an unknown German registration but I have added it in as the C77R.
Nothing on the others
Thanks Bratters, its in the d/b but for some reason didn't show for you so have recycled it through again.
CYYZGUY
40" LED Monitor
40" LED Monitor
Northern Watch
Hi Alan
Thank you for the information, I will take a look at it once I have played about with it somemore.
Keith
Morning, the unknowns from Monday:
3E1C9E nothing more
* 3F46BE  GAF183
* 3F785B  GAFN01A
I'll guess that most/all of the following are caused by bad packets received.
* 4B8E0E
* 48952D
* 4AC8BF
* 4CA270
* A24126
Regards Ingo
falcon_nl
3E1C9E gave me DICAO as a callsign
Ingo,
3E1C9E decodes as detailed by falcon_nl to D-ICAO but I can find no details at this time
Your others I can find no info on and the mil tac have been added
Could the user JAS who sent an Aircraft Database Error Report from EMA please contact me by email
